chicane
Anyone know where i can buy an (metric) M7 thread chaser (Internal)? So far I have only found kits and singles that contain even number chasers.
InternalInternal or external? Mcmaster has M7 chasers.
External:
https://www.mcmaster.com/2667A452/
https://www.mcmaster.com/2573A56/
My old Craftsman kit came with M7 thread cutters but I've never had to use them. Just curious, what are you working on that has M7 fasteners? Very curious.
If you can't find an internal thread chasing tap you can easily make one if the threads you need to restore aren't that badly damaged. Grab a bolt (same size & pitch of course) & grind a slot on the threads. Grind 2 slots if needed and you can even grind an angled slot at the tip.Internal
That is pretty clever. M7 is pretty small so I'd guess the slots would have to be quite thinIf you can't find an internal thread chasing tap you can easily make one if the threads you need to restore aren't that badly damaged. Grab a bolt (same size & pitch of course) & grind a slot on the threads. Grind 2 slots if needed and you can even grind an angled slot at the tip.
Come to think of it I'm pretty sure M6 is the smallest I've done it on so totally doable with M7. I used a dremel for that one. Just one slot should do it for that size. Could probably do M5 too but I don't think I've ever gone smaller than M6 or have ever needed too.That is pretty clever. M7 is pretty small so I'd guess the slots would have to be quite thin
