X Diagonal Brace in ceiling
Chuynh22
Monrovia, CA
Hi everyone,
In my garage, 20x20 there’s a diagonal C bracing underneath the rafter ties. Is there anyway I can replace them with something a bit more aesthetically pleasing and retaining its function? They are attached underneath the rafter ties.
MikeinNorthWales
SE Pennsylvania
I could be wrong, but it looks like the only purpose they served was holding the walls square before the roof was decked.
matt_i
I copied and pasted this from your last thread asking about same:
X cross beams made of wood? That's to help keep it square and not racking. I think you could probably replace it from 16ga metal strapping in an "X" pattern that would hide between the existing joist bottom and the new framing you're about to put up.
Check Simpson CS-16 for an idea of the product I'm envisioning.
Kaizen
New England
The walls look like 2x3 studs and 1x planks. Is there plywood outside of that? What about the roof? Any evidence of plywood? Looks like a lot of after the fact bracing which would make me hesitant. Plywood now adds a lot of protection from racking.
If no ply I think I’d add some cables or bracing up in the rafters. Did someone lay dark and light alternating boards on the roof?
C
Chuynh22
Monrovia, CA
Not sure, just bought the house a few months ago. It looks like under the shingles there is plywood .
The Cobbler
looks to me like the garage was originally built with cedar shingles, thats why the spaces between the roof boards. looks like plywood was nailed on overtop of the boards to lay regular shingles. if it has been well nailed, I don't think you need those X braces any longer
maybe you could remove them & add new on the other side of the collar ties too
kbs2244
If you don't like the look,
I would string tight cables in their place before removing them.
pbon
Cables work fine as cross bracing. It won’t hurt to keep an X but I agree that if your barn is now square you don’t need them anymore.
GMCGarage
Dont just take them out without something replacing them. I doubt the roof diaphragm is properly connected to the walls for load transfer. Now, if you dont mind it moving around a bit, take them out. It wont move everyday, but the day you get the big storm or big earthquake, could move around.
The Tool Tyrant
Bonita, Ca. (San Diego)
GMC is right. There is no roof diaphragm transfer to the walls. My (educated) guess tells me it was built in the early 60's as it has 1x6 'let-in' wall bracing rather than 2x4 'cut-in' wall bracing. Along with 1x6 'skip sheeting' for the original cedar shake roofing.
Metal strapping or cabling only works in tension, not compression. You could run 2x4 diagonal blocking between the 2x4 wall ties, with a short Simpson strap spanning block to block to tie everything together, then remove the 1x6 bracing. Not too tough.
manwithtools
Lebanon, TN
If the building is a rectangle (or square - which is also a rectangle) then a set of straps or cables that run from corner to corner will always result in one or the other of them being in tension - thus providing the desired resistance to racking.
pbon
I was guessing this was built long before the 1960s.
Falcon67
Merkel, TX
IMHO, they are not needed - but could be moved over the joists if you wanted and tied back into the top plates.
