Yankee Doodle Driver
LordPsychon
In your basement...seriously, go look now!
Does anyone know where I might find a Yankee driver? It's sort of a brace married to a screwdriver. My dad used to have one but I, er, sort of kind of broke it about 20 years ago. Now that I'm getting into woodworking, I remember how easy it was for more sensitive work so I'd like to have one. Any clues?
Dave455
Sussex, England
Fantastic tools!
The original ones were made by North Bros. and were superb tools. Millers Falls made nice ones too. Most would be considered collectors items now, though I still use my Millers Falls!
Stanley were probably the most prolific manufacturer. I believe they either bought out North Bros, or bought the rights to the design. They were made in both the U.S. and the U.K. Quality was good originally, but gradually got poorer over the years.
I don't know when Stanley finally discontinued these, but it wasn't long ago. You can still see the odd one in U.K. shops, but eBay is full of them, and you will often get a better tool buying a decent older used one, than by buying the last that Stanley made!
Aside from the model shown above, they have also been offerred by Facom, and these are my favourites of the modern tools. Facom were the first to offer one for use with 1/4 inch bits, and I used to use mine a lot working in mechanical assembly!
Bear in mind that if you use them for woodworking, you need to do a little more (some would say 'correct') preparation than you would with a cordless tool. You need to drill a generous size pilot hole, a clearance hole, and a countersink if necessary. Subject to that, and a supply of decent screws, you will get a result that is hard to better!
You can, of course, still get screwdriver bits to use with a carpenters Brace, or just get a Speed Brace / Speeder from whoever you favourite manufacturer is, and add some screwdriver bits!
Zrexxer
Pflugerville, TX
Ahh, the original cordless driver. I drove thousands of screws with one of those working in a cabinet shop in the 70's and early 80's. The day I got my first Makita 7.2V cordless, I knew that the Yankee's days were numbered, but I'd like to have one again for old times' sake. Maybe I'll order one of those Garrett Wade models.
MFolks
Springfield Mo.
A well used tool in the USAF for opening/closing the aircraft panels, when in the final check area before launch. Most have been replaced with cordless drills/screwdrivers.
rlitman
Long Island
The problem is that the ratio of push to torque force is not really suitable for Philips fasteners with these drivers. If it is at all tight fitting, it leads to camout.
It's fine with slotted, torx or Robertson though.
Current ones are made by Schroder in Germany, and there is a Chinese knockoff sold by HF that's actually not that bad. The HF one is designed to take 1/4" hex bits, and doesn't work with Yankee bits.
bonneyman
Desert SW
Keep your eyes peeled at estate sales and thrift stores. All of mine were had for less than $10 - two of them I paid $1 for.:shocking:
I've bought a pair of the Lee Valley adaptors. they are nice. And I keep coming across Yankee screwdriver tips. I'd say your odds are good, too.
