yards to tons conversion
mikeyp
lexington, N.C.
Our contractor says he needs 4yrds of gravel to fill in for a drain , I can haul 6 ton on my dump trailer. How many Tons is 4 yrds???
Stuart in MN
Minneapolis
Q: How much does a cubic yard of gravel weigh?
A: A cubic foot of dry, loose gravel with 1/4" to 2" stones is 105 pounds per cubic foot. So, a cubic yard is that times 27, or 2835 lb. (There are 27 cubic feet in a cubic yard.)
ihredo4
100 miles W of Daileyville in Idiotnois
If iis wet at all I would make two trips. You could end up over weight on trailer, Combined vehicle, and even tire rating depending on what tires are on the trailer. It wouldn't be worth the ticket to me plus it will not cost you that much more to make the two trips and be safe. Just my $.02
cream 46 sedan
I am a concrete contractor. I use yards x 1.5 to equal tons of gravel. also 80 square feet 4" thick is one cubic yard also 27 cubic feet is one cubic yard. I hope this helps.
nissan_crawler
Wichita, KS
yards to tons is a loose translation. I got a yard of gravel on one occasion, and it was 2800 or so pounds. The next time there was more dirt, and it was wet, and it was 3300 pounds. My pickup wasn't on the bumpstops, but it was close. I took it easy on the way home.
hetkind
Johnson City, Tennessee
I am able to haul about 2/3 yard gravel in my 1/2 ton pickup...better to make extra trips and spend a little more in gas than damage your truck or trailer or have a nasty overload accident.
Howard
ps: I am paying $14/ton for gravel
nate379
Palmer, AK
The stuff I hauled was about 1.5 tons to a yard. $10 a ton for 1" minus crush or $5 a ton for pit run. Hauled close to 40 tons in all.
My truck loaded to the bed rails holds ~4000lbs of gravel. I got tired of hand unloading after 3 loads so I hired a friend with Chev C50 with dump body.
brownbagg
you cannot convert yard to tons, ton is weight, cubic is size. But rock usually weigh about 130 cu ft compacted. so about 120 be close loose.
