Slowcorrado
- Joined
- Nov 5, 2016
- Messages
- 29
Sorry to post ANOTHER compressor wiring question. But, I'm a firm believer that you can't be too careful and thorough with this type of thing.
I have an old Ingersoll-Rand T30 I'm installing in my small garage and would love some clarification on the proper wiring. I'm located in PA (uses NEC 2012 to my knowledge). I've attached a pic of the motor information plate and compressor
Based on the plate I see it's single phase rated at 230 volts, and I'm guessing 25 amps? My 200A service is 50' away. The motor has its own external "control" box attached that has a reset.
So finally the question: Using copper non-metallic cable (romex), will 10/3 be sufficient and not overkill and what amperage double-pole panel breaker do you suggest? Basic logic says 30A, based on the wire size, but I thought there was some required upsizing based on startup current.
Suggestions and experiences welcomed! Any questions about my setup, please ask. Thanks.
