mindofone
I picked this up from a Craigslist seller. It’s a 1966 ‘Late Model’ Craftsman 150 Drill Press (113-24511) made by Emerson Electric. With the threat of public shaming for not starting a GJ thread since joining, I have attempted to outline my restoration of this wonderful drill press. I paid $150 for the drill press – including a partial delivery (half way to me) from the seller. Despite the fact that I live in a major metro area, there are surprisingly few ‘vintage’ tools that come on the market here. Either that, or I‘m just not looking in the right place which is either a blessing or a curse?
The drill press came equipped with a period-correct (whatever that means) Westinghouse 315P 164-A 1/3 HP, 1725 RPM electric motor and the associated Westinghouse Motor Snap Switch that was mounted on a simple piece of aluminum extrusion, bolted to the motor support bracket.
Although dusty, grimy, dirty and surface-rusty (also with an assortment of mud dauber nests for free), the drill press was in surprisingly good shape for being 50 years old. I’d like to think it lead a sheltered life. My goal was to give it a good cleanup, and run it as-is. Although I am quite envious of other people’s total restorations, I would almost be more afraid to actually use a drill press (or other garage tool) that was too nice looking. Invariably, I’m going to mess it up.
I also like to have everything on-hand before I begin a project, so after reading through pages and pages of other people’s threads (with copious thanks to FrankLee and David Doan), I ordered up some new bearings, new electrical wiring (the original was so poorly presented that I never thought of plugging the drill press in to see if it worked for fear of electrocution). A new belt was a necessary buy too, as the old one was WELL past its prime. The drill press had a drill bit already in the chuck, but no chuck key. How the drill bit survived unbroken in the chuck during the move after I acquired it is anyone’s guess! So, I ordered a used K3 Jacobs Chuck Key (two actually) off eBay and decided I would get some new stainless fasteners instead of reusing the old ones.
Items required for teardown:
PB Blaster
Miscellaneous sockets, wrenches and flat-head screwdrivers (including a general-purpose ‘junk’ screwdriver that surprisingly found many uses above and beyond just loosening screws )
2x4 chunk of wood
Broom Handle – cut down
BFH
Plastic Gloves
More PB Blaster
The first order of business was tearing down the head assembly. Although before I could dig into the head, I removed all electrical switch and wiring for the motor. That put aside, it was time to remove the electric motor and motor support bracket. I was met with an extensive amount of rust on the motor support bracket bolts. I figured it was time to use a little liquid persuasion, and so I began a thorough loosening procedure with PB Blaster. I’m pretty certain it would have been impossible to remove any number of parts from this drill press without something like PB Blaster.
After a few hours to let the PB Blaster do its stuff, I resumed disassembly of the head. I placed a small plank of wood on the drill press table to help support anything that might fall downward. That was my thinking, anyway.
Each of the quill lock screw holes on either side of the head had been filled in with some sort of chalky caulking material. As a result, those screws were not accessible to the previous owner. Weird. The holes got scraped out and after a quick tap of a hammer on the screw driver, both screws came out. I noted the suggestion that these screws be replaced with 8-32x3/4 socket cap screws.
I removed the locks, handles, bolts, and other necessary bits from the head assembly and using a set of curved needle nose pliers, I unhooked the feed return spring and prepared to remove the quill assembly by pulling it down and out of the head. However, it was stuck, and would go up, and down, but would not come all the way out. After a little persuasion with a 2x4 piece; a cut-down broom handle and a BFH, the quill assembly slid out of the spindle pulley and both were removed from the head assembly. A little further inspection revealed that the upper splined portion of the spindle was somewhat corroded, and was sticking inside the spindle pulley. Most certainly a candidate for cleaning and polishing. The good news is, somewhere along the line both bearing assemblies had been replaced with some nice sealed bearings which are in excellent condition. I guess I have some spare bearings to keep on the shelf.
I also took note of the warning to NOT loosen or remove the lock handle until the drill press head assembly was either on the ground or otherwise supported as (a) it’s pretty heavy, and (2) guaranteed to crash down and likely damage a number of things and hands. As it turns out, the head assembly was more or less stuck on the pole – it would move a few inches up, and a few inches down, but not come off the top of the pole. I resorted to lowering the head assembly (now empty) and sanding to pole at the top to try and remove any and all rust and corrosion that was keeping the head from sliding off. Success eventually prevailed, but was much harder to come by that I would have thought.
I didn’t have a short enough tool to punch out the spiral screw ‘things’ that hold the Craftsman aluminum band on the head, and so used a small Allen wrench and a hammer to push each out. Fancy.
Items required for the Cleaning:
Mineral Spirits (non-odor)
Acetone
Wirewheel Disc on a Benchtop Grinder
Heavy-Duty Scotch-Brite pads
Brass Wire Brush
Shop Rags/Blue Paper Towels
Medium-size plastic tub
The Quill assembly was coated on the upper portion with very old oil/grease baked-on residue gunk. That portion of the quill remains hidden inside the head, so at first I wasn’t going to do anything about it. However… after cleaning everything else metallic on the wire wheel, I let myself polish up the quill top. Then the middle. Then down near the chuck. Then the chuck. I was holding the quill assembly with both hands, and very shortly the chuck and spindle were rotating as fast as the wire wheel. In hindsight, probably not a smart thing to do, but the bearings were super quiet, and I felt no resistance. So, that part of the assembly is now well tested
PB Blaster
2x4 chunk of wood
BFH
Plastic Gloves
More PB Blaster
Acetone
Brass Wire Brush
