yet another gutter leaf guard question
87GN
phila, pa
With today's nice rain storm, I see my gutters are overflowing so I assume I have some clogs. I read through numerous leaf guard threads on G.J. and I'm still not sure which ones to get. Some says this brand is good. Then someone says this brand is no good and get to get that brand. Some else says no to that brand get these. So, at this point in time, what is considered a good brand/style to get? Tomorrows job is to go clean out the gutters and downspouts and hopefully buy some guards for next weeks project. Thanks.
Mark
TJMtl
Montreal
My house has some good leaf guards, but they failed due to shingle erosion which made it through and clogged the downspouts. No leaf Guard is maintenance free, and the fact that they clogged was because they are not easy to check.
I have T-Rex gutter guards.
T-Rex
Sumboodie
AK
If it's fairly easy to clean, just do that.
Mine are only ~10ft up. I just rinse them out every couple years. Mostly cottonwood fuzz and silt.
MushCreek
Upstate South Carolina
I'd like to find some that actually work. The ones that advertise non-stop on TV are unbelievably expensive, costing several thousand dollars for a small house. I have some screen-type ones that work OK for leaves, but the oak pollen clogs them up every spring. I blast them out with a hose, but the back of the house is 20' off of the ground. At my age, I barely do step ladders any more.
Before I had gutters, the rain dumped off of my metal roof, plowing a rut in the yard.
FMB4
I used the cheap flexible plastic screens for 3-4 years. And, as mentioned above, I still had to remove them every year due to debris that made it's way past the screens. Said screens were not hard to remove or install, but I ended up leaving (har-har) them off. Now all I use are the aluminum screens that fit into the downspout openings.
CraigStu
Blacksburg, Va
We have the expanded metal style installed by the builder. He offered us 3 options, these were the least expensive, he has them on his own house and is happy. I am happy too. When I look out our bedroom window I look directly down on the 5 ft front porch roof so I look right at the top of the gutters. They have been perfect over 2.5 years. Ours are similar to these.
We had the foam rubber ones on our previous house. They were OK until they started to wear out. All the tiny stuff stays in the openings and eventually they are almost a solid top. They are really ugly to remove when they are done.
Showkey
"MEMBER EMERITUS"
Wausau WI
Don’t think anything changed from the prior posts:
1. certain situations you may have clean the screens once or twice per year, more in the 90* corners.
2. foam or brushes don’t work in certain situations. Don’t last in the sun…..
3. Some of the choices are $$$$$.
4. No solution is 100% maintenance free.
BillK
Beautiful Southern Maryland
I bought these from Home Depot about 10 years ago. They are so cheap it was worth taking the chance. Well they have worked great for 10 years :) I had to replace one because a small branch fell on it and messed up the screen but otherwise no problems.
FredWanaker
NorCal
if one story, special wand that hooks up to your brand leaf blower. You just walk along and blow out the debris whenever you want.
LS6 Tommy
Northern NJ
T-Rex
I disagree. My Gutter Glove gutter guards have been 100% maintenance and clog free for almost 30 years...
IMO there's no other option.
Tommy
65ranchero
Danville, VT left NJ forever
I had the plastic mesh ones on my other house after getting tired of climbing on the roof and cleaning out all the maple seeds (helicopters) out, then hiring out to clean the gutters ( which I was not happy with the way they did it).
The plastic mesh lasted for a couple of years until the squirrels figured out how to pull the mesh off and get the maple seeds that got passed through the mesh.
Wound up taking them off and cleaning the gutters anyway!
tried the expanded aluminum mesh in the down spout opening , still had to clean them. so I moved!
rburke65
Canfield, Ohio
Well it’s all opinion! I installed the aluminum diamond shaped stuff you screw to the aluminum gutter..?..4’ pieces. So far so good.
FMB4
My wife and I will never buy another house with large deciduous trees on the lot, or nearby. Problem solved.
Showkey
"MEMBER EMERITUS"
Wausau WI
They are maintenance free if you don’t live in the woods.
The definition of “woods“ might be………
100% shade in summer
it hard to see the stars
its incredibly dark on moonless night
very difficult to grow grass,
moss grows way better than grass,
you measure your leaf piles in feet,
you shovel acorns when they drop.
HPRifleman
Member Emeritus
Wayne, IL
This might fit your definition.
gj_t-jpg.1479954
mv213
Dallas, OR (the OTHER "Big D")
Tommy
I like the idea of those—how do you deal with the debris (leaves, needles) that build up on top of the filter? How often do you have to do it? The actual “Leaf Guard” brand is horrible, in a heavy rain leaves can flow right into the gutter and they are tough to clean out then.
LS6 Tommy
Northern NJ
I don't. Nothing builds up. The guards are mounted at pretty much the same pitch as the roof. Keep in mind, I have a Cape Cod, so I have a steep roof pitch. I could see a roof with less pitch have a few leaves or needles on the gaurds until the wind picked up.
Tommy
olytdi
Olympia, Washington
I, too, have the Gutter Glove stainless covers and they're the solution I'm most happy with. I've used everything else including plastic covers, flip back arched covers, foam and brush gutter inserts, empty gutters, etc., -- except the Leaf Guard which looks like a viable solution for those with no leaves and only light rains.
I bought my Gutter Glove covers a couple of winters ago when there was a Home Depot sale. They ran under $400 for my 1750 sq ft house, garage, and the well house. Was able to install all in a longish day. Very straight forward.
They give you a coupon for a very useful brush in case you need to clear off the top of the guard which I've done twice yearly from the ground with a telescoping pole. I live in the woods. Takes about 10 - 15 minutes to do all of them.
I've not found a sturdier, more cost effective, and low maintenance solution.
Mikeske
Washington State
I run nothing on my gutters and have only cleaned them 3 times in the last 22 years I have lived at this location. I think it has something to do with the fact that I bought this land and it used to be a pasture. I liked it after seeing what a tree did to my buddies house it center punched and destroyed the house. I planted trees but they are 30 to 60 feet away from any of the structures. So gutter maintenance is easy for me.
glentre
Gloucester, Virginia
As I said in a previous thread on the same subject, no gutter guard works except one. That is the kind with no cap or screen but is hinged and can be swung down to allow the leaves to fall out or hosed out from the ground.
Glen
67carl
California
I was looking at one Costco sells and is very popular. Looks like the same design as the Gutter Glove mentioned above. The Costco one is $2.00/ft while Home Depot has the Gutter Glove on sale for $1.75/ft. These have been on my to-do list but ranked pretty low... I may need to move it up.
https://www.costco.com/easyon-gutterguard-5”-version---100’.product.100019377.html
Mr_fixit
Rustylvania
Make sure you consider the snow turning to ice with most better gutter guards. No one mentions the problems of winter, during the sales pitch.
