brownsl
I am getting ready to insulate my 32' x 52' detached garage and I am confused on what to do. I have read every thread on these forums about insulation and it makes me more confused.
First, the garage is constructed using 2x6s with OSB, Tyvek wrap, and then the metal siding on the walls. On the roof, OSB, some kind of paper, and then the metal roof. I am definitely going to get some spray-in foam to reduce infiltration. It will be closed-cell but I do not want to pay the price for completely filling the wall stud space. So, I think I will use 2" - 3" on the walls as opposed to using only 1" and then using batts.
That seems relatively straightforward. Where I am confused is what to do with the roof/ceiling. I have a ridge vent and soffit vents. My two options seem to be
1) I am putting up an OSB ceiling so I could put the foam down on the attic side of the OSB and this would allow the attic space to breath. If I put a couple of inches down I could then put some blown-in insulation down on top of the foam. A benefit would be that it would be less volume to heat. Even though I will be heating it infrequently.
Or,
2) I could put the foam directly along the roof and on the eaves. A negative would be more surface area so greater expense. Some people tell me that I could just spray closed the ridge vent and the soffit vents and I will be fine. But I am concerned about with an OSB ceiling how will the attic space breath, if it even needs to with the foam along the roof.
Any advice would be greatly appreciated.
Or,
