Good Afternoon,
I wanted to ask the experts, while I am impatiently waiting for my HVAC/builder folks to return my calls & texts requesting help. Also, I have an engineering background, so my curiosity is also being challenged.....
I have a York Affinity Heat Pump, installed February 2015. I have had multiple Error Codes for this unit and since Saturday, I hear the outdoor unit compressor running, but the fan is not. Outside temps ~ 30F to 55 F over the past few days.
Equipment Details:
Model
MV20DN21C
YZH04812C
FC62D3XC1
S-1-1TVM4H1
S-1-TTSCC02
Logs
Outdoor Equipment Fault Liquid line sensor failure - OPEN
Outdoor Equipment Fault High Pressure switch fault - not in lockout yet
Outdoor Equipment Fault High pressure switch lockout - Last mode of operation was heat pump
Outdoor Equipment Fault Low voltage (below 19.2VAC) preventing further relay outputs
Outdoor Equipment Fault Fossil Fuel Mode Steeing Error - FFUEL Jumper in the off position with bonnet sensor present
Outdoor Equipment Fault Defrost Jumper Error - Invalid jumper setting prevening compressor operation
It appears that the thermostat only holds the logs for about 1 year. There is NO Fossil Fuel connected to my Heat Pump.
Thank you in advance for your help!
Mike
Equipment Details:
Model
MV20DN21C
YZH04812C
FC62D3XC1
S-1-1TVM4H1
S-1-TTSCC02
Logs
Mike
