Alchymist
Sears has been running a special on the LV-4, a "homowner's" vise. Well, at $17.95 shipped (with some SYW points), I couldn't resist. I wanted a little bigger vise to replace the 2" one on my small wood lathe bench, so I grabbed one, even though some comments here and other forums said the swivel base didn't lock well.
Sure enough, when tightened down, the vise body would chuck back and forth a little. Didn't take long to see that the body was pivoting on the locking bolt, as the center bolt hole was too big for the bolt that held the vise to the base.
The fix was simple = a strip of .035" steel stock about 1/4" wide wrapped around the shoulder of the center bolt. Locks up tight, no movement whatsoever. (If it wears out, replace the strip.
). Oh yeah, I added a washer under the swivel lock - just because I could!
