WOW... You've done it again Royce....![]()
Your imagination and workmanship are AMAZING....
I see you have a 36 in. Starrett combo blade....
Lynn
Nice work on the stand. Seeing all the pipe you use it reminds me of the casing used in the oilfield when I worked in North Dakota and Colorado. The welders always made it look easy torch cutting the casing and welding on the wellheads. Do you have any experience in the oil field? I spent a few weeks up on the north slope doing well exploration back in 2012.
Royce I would like to ask what you used or how you created the 1/4 spherical ends on your tool tray? I rarely see that shape in structural pieces I can salvage. In solid and plastics somewhat available but again in structural shapes rarely/never. [I tried to form some 16 Ga. with no joy].Harry
Again thanx for corrupting us! ... I mean sharing![]()
The reason I noticed yours is because I have a standard 1"X36" blade to fit regular combination square heads.. The only one I have ever seen in the wild... Thought yours was one also.... have seen them in the catalog...Thanks Lynn,
That blade is 1-1/2" X 36" for a #8 square head.
I don't think it is stock and it is the only one I've seen, I believe someone milled the groove in a stock rule blade, but not certain.
Royce
