Lots of cheap tool surprises, love those! Hmmm, what are my favorites...
First thing that comes to mind is my Harbor Freight 18 Piece Disc Brake Pad and Caliper Service Tool Kit (#97143). I figured it was cheap enough to give it a try, and if it sucked, I would use and abuse it until it broke and then get something better. I was pleasantly surprised to discover that the fit and finish are excellent and it seems to function better than some tool truck sets I've tried. I'm very, very happy with the material quality, machining, and finish, and the case is even great. Most importantly, it has both right and left hand threaded spindles, necessary for Jag X-Types (plus I'm guessing Ford Mondeos/Contours and Mercury Mystiques, at least). The equivalent Snap-On/Blue Point set has only 7 adaptors and appears to only have the right hand threaded spindle...and for that, costs $270? Doesn't even look like it would get the job done. And MAC is selling (DBC18B) what looks suspiciously like the exact same tool set in a slightly different case...I wonder how much they charge, since their website won't tell you any prices. Anybody have that one?
Probably the very best cheap tool surprise, and my best cheap tool purchase period, is my Ace Hardware Pro Series 12 Piece Torx Bit Socket Set (#29192). I use the damn thing every day and couldn't be much happier with it. Hell, I even still use the plastic holder they came on (probably should get something better, but it's working just fine for now). I've used everything from the T10 to the T60 with great results. Okay, one or two of the 3/8" drive ones below T60 I've probably never used (is there really such thing as a T47 bolt, or is it just a myth invented to sell sockets?), but most of them I have, and certainly the T30 and T25 have seen more than their fair share of action and don't seem any worse for the wear. Also, I will put the T60 on a 3/8" drive to 1/2" drive [non-impact] adapter and put that on my MG725 and use it to impact off (and back on) the bolt holding the lower A-arm to the knuckle on the larger Jags. First time I did it, I expected that I would probably twist the **** out of the socket, and then I would give in and buy a real impact T60 off one of the tool trucks or something. Except I went slowly, and found that it survived and wasn't even dinged in the slightest. And every time since. Still not the slightest damage. At some point I may get an expensive T60, T30, T25, maybe even T20, T15, and T10, but this set refuses to give me any excuse to do so.
