Your Favorite Small Gas Engine Tools!
Farmall450
Marengo, Illinois
I'll start off with mine...
Inline Spark Checker
Saves the PITA of taking off and then putting back in the spark plug. I also have a similar one that grounds to the engine vs the plug.
Hook and Pick Set
Invaluable for many things.
Points File
And of course, don't forget about Sea Foam, that's a tool in my book!
F
Farmall450
Marengo, Illinois
How do you use Sea Foam in your small engine work?
Just trying to learn something here.
:thumbup:
Well, ethanol tends to mess stuff up...so often if an engine is running rough and you don't necessarily want/need to rebuild the carburetor, a shot of sea foam and some time idling will clean it up. It's especially good for the first time you fire something up in the spring, mower/weedeater/chainsaw/etc.
Wakefield
Arlington VA (but would like to get out to country
Super Jet Spray Gumcutter(!)-although I don't think it is safe around plastic(like the nozzle inside of later model Tecumseh carburetors might eat gaskets and paint?
vibratach if not something more sophisticated flywheel tools B&S starter clutch tool
flywheel nut or starter clutch needs to be torqued! piece of plastic air gap gauge for setting distance for "magnetron" or whatever from the flywheel (instead of the business card that everybody uses
Good 1/4" drive stuff and a good little torque wrench/screwdriver
Is the Tecumseh screwdriver still available? (Helps set the float height and pull/install seats "Viton" for the fuel inlet needle)
Jet screws still available? (the "nut" that holds the bowl on the carburetor has a fuel metering hole in it in some designs) Forbidden to poke tiny drill bits in those holes?
Extra o-rings and gaskets for carb bowls and bowl nuts? Extra fuel hose (for making replacement) and little inline filters and shut off valves to add to your mowers?
Low strength Loctite help stop sheet metal screws from coming out?
I have a Briggs spark tester that I understand if it will show spark then the spark is strong enough for the engine to run! (Harder to fire it than the old spare spark plug out of the engine trick)
F
Farmall450
Marengo, Illinois
I wouldn't say hose, o rings, and filters are tools, but indeed very handy. I have a few spools and assortments of such parts.
I figured more specialty tools, like flywheel holders, and the plastic gap gauge, very handy, as are long flexible feeler gauges.
SO ratcheting screwdriver is super useful IMO, about all you need, and everyone should have a good 1/4" drive set!
jakemac
New England
Marvel Mystery Oil and Marine grade Sta-Bil (the blue stuff, not red).
Ohhh ........... and a really big hammer ! :lol_hitti
SnowDrifter
....A power drill to crank it so I don't have to keep fussing with the pull start? ;)
bobcatdan
Kaukauna,WI
The correct socket for removing starter clutches is very handy. The brass knocker for popping flywheels is a real time saver.
chipper
Williamsburg, va
littletoes
NE Washington
1/4" drive tools in EVERYTHING! Torx, philips, standard, metric, sae....long extensions, top quality ratchets and adaptors-they all make the job easier.
Easy outs-4 corner square ones. The spiral types make getting out broken bolts harder!
Bottoming taps to clean out rusted holes.
Spark plug taps to chase bad threads.
Not a tool, but copper anti-seize for various jobs.
hmmmm......what else? ;)
DekeT
USA
I use those same Masterforce picks all the time when digging around inside my small engines. It is my first choice for useful small engine tools.
Second is my valve spring tool. Third is a tie between my ring expander and squeezer.
southalabama
Brewton AL
Sea foam and stabil are your friends for small engines.
I've got a lot of husqvarna equipment and the manuals describe a specialty tool. The local dealer and I graduated hs together. In a small town that means we went to school 12 years together. I was looking at his shop one day and asked him about specialty tools. He didn't have any other than those he made. His life would be so much simpler if he bought the husqvarna tools. Then again. He does it for a living and I was just looking for a cool new tool to buy.
joel63
Central FL
Thanks for the tip.
:beer:
Farmall 1066
Suburban Rockford, NE
When I worked on power equipment, the Snap-On CT-30 cordless impact just came out. Within month, everyone in the shop had one!
Another favorite is this slotted cast iron disc, used to back up stamped pulleys so you can use a gear puller without damaging things. Think I got it from Stens.
humber2
Downunder
My go for tools for Bugs & Scrapiron
1/4 and 5/16 Nutdrivers
1/4 ratchet, extension and 7/16 & 1/2 sockets
15/16 boxend wrench for flywheel nut
9/16 6 point wrench for mower blade bolt
Tapping stick
Zim #131 valve spring compressor.
Spark plug wrench
Quite happy to store a bust engine with broken con-rod or seized as there's proof both carby and ignition were working to do that.
One of the best "tools" can not be purchased ! Well at least not directly. The best thing for cleaning a carburetor is a fine, stiff wire.
Take a hand held wire brush and pull out a single strand. (Likely more than one will come out because they are placed into holes in clumps using a small staple.)
Use that single strand to probe/"ream" out passages/jets. Then hit them with some spray carb cleaner.
Spudland_Dave
Maine
Seafoam....Nectar of the Gods. I had to eat crow on this one...for a while my dad was telling me how good it was, my buddy at work and i would laugh all the time when my dad would tell me about it, now my buddy and I are "True Believers".
You couldnt PAY me any amount to use Sta-Bil anything.
bob_the_builder
Does anyone have a model or part number of the in line tester that will ground the plug to the engine block? I already have the standard in line tester but the other would be great.
Bob
msgtsmithret
Raleigh NC
I don't have a picture to share, but my favorite small engine tool is the pull start winding tool. You can purchase one, but they are simple to make. An 8" long piece of 3/4" ( approx.) Square stock with a drilled passage to accept a dowel near the top. Put the dowel in the square stock and insert it into the underside of the rewind mechanism on most pull start engines. Just twist it several times to rewind the clock spring when replacing the pull cord.
Coach James
Sandhills of North Carolina
Ok. There must be a story here.
Coach
Spudland_Dave
Maine
Coach
There is... :eyecrazy:
So one fall as part of my "winterizing" I Stabil'ed all my OPE...luckily I hate gas powered anything to begin with so it only consisted of my shiny new Mantis Tiller and an older String Trimmer (I've never seen a diesel weedwacker, but I'd love one :beer:)
Well fast foward 4 months...spring is upon us and what do I have to deal with...a Mantis which is completely gummed up with Red Gunk, and the weedwacker was no better...luckily I got the mantis running with the help of some SeaFoam.
Since then, i've stayed away from Stabil and used nothing but sea-foam. Spring times are now a time of enjoyment...2 pulls and my equipment is running. No more cleaning red goop. Since then, between my buddy and I, we've drug home some basket cases which ran like **** when bought...2 tanks of Seafoam treated fuel later they are running like new. So I for one, completely agree with the OP when he says Seafoam is a tool for Small Engines. Its no cure for mechanical failures, but IMHO most small engine problems are "Gunk" Related..just arent used nearly enough. Combined with a disposable society, means that there are tons of small engines at recycling centers or garage sales which can be back in running shape for the cost of a spark plug and a bottle of SeaFoam.
F
Farmall450
Marengo, Illinois
Definetly the square ones...I have williams myself. :beer:
The picks rock and they're economical, US made pratt reads.
A partially clogged carburetor can frequently be cleared be a heavy does of SeaFoam (about 10 times what the can says).
At least 10x :lol_hitti
I use torch tip cleaners! :beer:
Bob
I believe HF makes one too, but it is pretty rare you come across a bad plug that won't ground.
It's good stuff; I too dislike Sta Bil...sea foam is worth the money.
What is the ratio of sea foam to fuel you use.
Bob
It says it on the can; I typically give it an overdose though.
Bob
If you are trying to cure the very common "engine revs up and down" or "will only run with choke (partially) on", I have been known to put a half of a can into the tank of a typical 5 hp small engine.
10+ hp garden tractor, the whole can.
If these problems keep coming back, remove the gas tank and dump the fuel through a clean rag. See anything ? Well, you should NOT !
For a small tank pour a small amount of denatured alcohol or fresh gas in into and swish it around. If you had any rust flakes, add some small nuts and bolts and agitate. Drain through a clean rag again looking for debris. Repeat until it is clean.
NOW clean the carb !
joel63
Central FL
I must say be very extra careful using that "fine stiff wire" when repairing diaphragm carburetors.
I had a good friend ruin many carburetors with that "fine stiff wire."
I never could cure him of doing that, but then he was an excellent Diesel mechanic.
Bottom line, know what you're doing when doing carburetor repairs.
:thumbup:
gungatim
west mich
F
Farmall450
Marengo, Illinois
They stock those at pretty much every farm store, parts store, and box store with a lawnmower section. Surprised you can't find them. I buy a lot of my small engine stuff from MFG Supply, and they also stock that style as well as about 10 others.
http://www.mfgsupply.com/smallengine/smengfuel/smengfuelvalves.html
I can, i'm just trying to get the price down from $4/each!
eBay. You might have to buy 10, but they are cheap !
Cheapest I can find
http://www.ebay.com/itm/In-Line-Fue...406?pt=LH_DefaultDomain_0&hash=item1c30796526
:dunno:
F
Farmall450
Marengo, Illinois
G_P
Central CT
S/O ratcheting screwdriver with a hex to 1/4" drive adapter so I can put sockets on it.
This works great, but make sure the socket is secured to the drive tool!! Had one horizontal shaft engine fire up and when I went to pull the drill away the socket stayed on the flywheel:eyecrazy: Before I could get the engine shut down that socket took off like a chrome meteor and it took me 20 minutes to find it. Had it hit me in the head I would have been in the ER!
