Your stud finder recommendations?
ozyborn
Geartow, I hang TVs for a living. Along with entire HT systems.
I use the CH-Hanson magnetic one more often than anything else. Finds the nails in the lathe/plaster walls.
6PTsocket
Franklin 710 or Precision Sensors Profinder 5000, I think they're the same, just different color. May be others that are the same (Bosch?). I never use the old Zircons anymore.
View media item 58785
Right. Same one I got in blue from Costco. They sold them with a tape measure at Sams under some brand name. Franklin is the manufacturer. Later models added a bubble level
6PTsocket
This is an old thread but since it was started the Walabot has come out. It works with your cell phone to give you a "picture" of what is in the wall. Anybody tried one? They sure advertise a lot.
engineer2
Chicago burbs
Reviving an older thread. I have a Franklin 710 stud finder and hate it. Painfully slow and pretty much only works on 1/2" drywall with no mud or tape joints. Maybe I got a bad unit? Horrible battery compartment design.
Zircons were donated to Goodwill. No one even wanted them from the "free" table at our garage sale.
Any new models out there? Anybody like the Walabot? It gets very mixed reviews.
FigureItOut
Bentonville AR
I'd definitely give another one a try. It's a solid stud detector. It reportedly won't work on lathe and plaster, but I've had good results with it through two layers of ½" drywall.
Sent from my SM-G960U using Tapatalk
Hytekrednek
Franklin for me as well. My old, one of the first Zircon units, finally died. It worked great. I replaced it with another Zircon, it sucked. Tried another... it sucked worse. Researched them and found Franklin to have the best reputation, plus it is affordable. I really like the way it displays the entire stud, not just the edge.
Hytekrednek
The old and simple Zircon I had for decades was awesome and reliable. I give them credit for that. Something changed with their company for sure as it seems all zircon models **** now. If I had to guess, I would say it is either maximizing profits that ruined them, or getting to ambitious with their designs, trying to make them do several things instead of just finding studs. My money is on both... cheaply making complicated designs leading to selling over hyped junk.
Yep, still love my Franklin. When I hang very heavy or expensive stuff, I may verify a studs location using a very skinny nail or ice pick.
ChrisLS8
I just use a Stud Buddy. Made in the US, dirt cheap and works better than any electric one I've used yet
Wyoming09
Wyoming, MI
I been using one of these for the last 30+ years. It's never let me down.
Parrothead
Earth
Some great tips guys, thanks! :thumbup:
Apologies for being lazy and just posting up the question when I shoulda known this would have been covered elsewhere. I think I was just at my wits end in the garage the other day screwing around with my Zircon POS and typed up a quick topic on the forums!
This is like the Zircon one I have:
http://www.amazon.com/dp/B000055X0X/?tag=atomicindus08-20
But looks like I'll be stepping up to the Franklin one now instead. Wow, for 50 bucks vs. 20 I can see that you certainly get what you pay for. I'll gladly drop another 30 bucks for less swearing and backaches from doing the same stud search 10 times over with that worthless Zircon one!
Save yourself some cash, they’ve got them at Menards for $35.
https://www.menards.com/main/p-1444430676953.htm
gwunsch
Murrieta, Ca
CH Hanson magnetic
I have had a few electronic stud finders, cheap Zircon, Ryobi, but got frustrated with false readings and inconsistent readings. Went back to the CH Hanson magnet and it has been great for home diy use.
engineer2
Chicago burbs
So I tried my Franklin 710 again today. Batteries were 1.5V each. I built the walls, so I know where the studs are. Random LEDs that didn't correspond to anything. Sometimes the LEDS were off where there was a stud and sometimes it indicated the stud was a half inch wide, maybe. Looks like it's going in the trash.
mc4life27
I second study buddy. I own a zircon but hardly used it. It always seems like when ever I need to use a stud finder mainly at work my zircon is in the car or at home and we have the stud buddy's all over the place at work and end up using them. They seem to work great only if the dry wall was put up correctly and used the correct amount of nails. Some building I have been in the remodel jobs were done half assed (work done before me and most of the time having to fix the work that's been done) and the drywall was. Not put up correctly and sometimes it's a pain to find the nails but over all I like the study buddy.
volleyball
NY, not NYC
If you have one of the many recommended smartphones than a walabot is the way to go. It shows you inside the wall visually
climb.on
Minnesota
A carpenter buddy was helping me trim my house and showed me this magnetic stud finder tool Rack-A-Tiers 52300 Studball. Similar to the CH Hanson. Freaking awesome. So simple and only $15 on amazon. My POS zircon, didn't get used again. The zircon does work, just not nearly as well.
JRas
Phoenix, AZ
I use a Zircon at work, middle model. Works pretty good, sometimes you use it on something that just isn't going to work well though. Works ~90% of the time with the short and deep sensing modes.
MikeF2316
Thornhill, ON
My inner walls are 3/8" drywall covered with a layer of mortar, then a couple of layers of plaster. The Franklin works fine on them. The Zircons I've bought I wouldn't even pick up off a free table at a garage sale either.
JRas
Phoenix, AZ
<iframe width="560" height="315" src="https://www.youtube.com/embed/IVkNyhmRO1k" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anyone try Bosch' offerings?
I have a cheap Zircon, but I do not trust it to find the exact center of a stud.
I was hanging a TV bracket for a 48" TV (bracket say it is good for up to 60"). Came with 4 good sized lags. Big enough, that is you did not hit the center of the stud, you were in trouble ! I got close with the Zircon, but i confirmed by drilling multiple tiny holes (which were going to be cover by the bracket anyway) and testing until I found the true edges.
Sdot
Loading
Smiling because the only stud finder I owned was a Zircon and glad all else reiterate what a POS it is. To make it worse - this one was an 'edge finder' not even stud finder.
Looking to buy one for use in wood - are all recommendations here still relevant?
Indexmill
Central NC
One guy in our neighborhood got sick and tired of the ****** Zircon not working and bitched to me about it. I mentioned the Franklin. The next day he had the Franklin from Costco and invited all of us to a campfire to see it. The only rule was that we all had to bring our Zircons... you can imagine the rest of the story.
