Youtube fab tips and tricks library
Firebrick43
West central Indiana
I originally saw that procedure shown in a very early edition of HSM magazine and they used a weight and cord wound around the spindle to keep it in place against the stop.
That sounds like it would work well for most indexing. And very simple!
I am glad you posted this as I was thinking about the guy that showed it to me all those years ago.
He used a small block of hardwood with a radius cut to the chuck and a small machinist jack on the bed pushing up on that block into the chuck. He manually He didn’t tighten it real hard, just finger tight and a quarter turn with the tiny little Tommy bar.
RoninB4
Under My House
-The above are good ideas instead of guess-timating or using other devices/methods. New lathes and most competent shops had a small block/cylinder that was the center height of the spindle at the ready. It often got misplaced, lost, or became a component for something else. For lathe owners it should be your first project IMO, just takes some measuring and a little math. Bolting it to the lathe cross slide is convenient but will be dangerous if the "birds nest" from turning hooks onto it. A dead center can also be made cheap/easy/simple in the lathe chuck for center height but doesn't help when you have to change the cutting tool and don't want to remove the workpiece from the chuck.
C
ching0n
they're both magnetic, the 2nd one only looks like it's bolted. I saw another approach that combines both. A cylinder hinged at the center height to approach from top or bottom, I think I'll be cloning this one:
C
ching0n
Three boring head tricks on a lathe:
Boring Head Tailstock Offset for turning tapers w/o readjusting your tailstock [you can skip much of the work buying a screw on boring head with a morse taper arbor to match your tailstock]:
Turning balls using a quick change:
variation of the above w/increased offset & worm gear anti-backing:
Boring but that's boring. The novel thing here is not using a chuck but taper for max concentricity I suppose. You can throw small stock into a tool holder if you don't have a milling attachment:
C
ching0n
variation of 1st video but w/captured ball bearings instead:
C
ching0n
Some simple coolant & cutting fluid delivery systems
I'm making this one w/a drip oiler so I don't have to build it:
