myredracer
I have a couple of cars I'm restoring and will need to zinc plate various nuts/bolts and parts & pieces. I know it's been discussed on this forum a lot. Doing some googling also, I find all sorts of pros/cons, cautions, recommendations and that make it kinda like trying to nail jello to a wall...
This guy on the AlfaBB forum seems to have a pretty good detailed how to thread here: http://www.alfabb.com/bb/forums/car-restoration/188194-zinc-electroplating-guide.html
Is it simply easier to just take a bucket of stuff into a plating shop and let them do it? Is there much of a cost advantage to doing it yourself? I hesitate to buy more "junk" that will take up yet more space in the garage and I hesitate at the amount of time it'll take to figure it out and to get it done right. Doesn't sound easy to make sure you get the right mil thickness of plating on surfaces. If I were to buy a kit, they look costly and it sounds like you may get some things you don't need or many not get some you do need. Not sure if getting a shop to do it is expensive or not.
Does anyone have a link to a good read(s) or video on zinc plating of car parts that might be better or have additional info. than the AlfaBB thread? How about a good source for individual things you'd need if plating yourself like zinc plates and chemicals?
If I get a shop to do it or do it myself, the pieces are all going to need cleaning to bare clean metal. Been thinking of some ways to accomplish that. A vibrating tumbler sounds nifty but can cause damage to some parts like bolt threads for ex. Muriatic (HCl) acid is an option but is dangerous to work with and will cause flash rust. Many parts will already have cad or zinc plating and does that need to be removed and if so, muriatic acid would be good for that. Ospho is another option but not sure if it will interfere with plating like it does with paint/primer. What about glass bead blasting? What I'm not sure about is, does cleaning to bare metal by any method (except phosphoric acid) all result in flash rust anyway? If so, just do a quick application of Ospho right afterwards?
I used to have a neighbor that restored high-end vintage cars for wealthy clients and he said the best thing to do is just toss everything into a bucket and take it to a plating shop. Easy for him to say tho. considering what he'd be charging clients for projects.
