rattlesnakehoey
Greetings Folks, any ideas on organizing & storing Zip/Cable Ties?
pvc pipe cut to different lengths with a cap on the bottom. If your cut em at an angle, you can put a screw through the back to mount them to a work-bench or wall. It's really handy.
I don't get real OCD about it,they are just stored in a shoebox sized plastic bin.
I've been sliced by many cut ties. I use this flush cutter and there are no sharp edges.Sorry - no suggestions for storage, but here's a quick tip for you zip tie users:
If you nip off the excess tail with a normal side cutters, it will leave a sharp burr where it was pinched off. Sometimes this is no big deal. But if the tie is in a spot where you are at risk of getting cut from a burr like that, simply nip it off with the tie turned 90 degrees in the cutters (tie perpendicular to the cutting jaws). It's not hard to keep it from flipping over flat while cutting. For some reason, it doesn't leave a sharp burr.
I don't remember how I discovered this, but it works like a charm.
Here is the way i store my zip ties on my work bench in my big shop,
