Not in my shop or yard but work none the less.
Just as I was about to leave work yesterday I got a phone call asking if I could stop by my wife's grandmother's home and take a look at her sprinkler system.
Upon arriving I determined that the timer was incorrect and she informed me that she panicked and unplugged the timer last week. She is 93 and still living in her home and her husband who passed away four years ago was **** about his yard, vehicles and pretty much everything. I worked on his vehicles over the years and I was honored that she requested that I come and look at her sprinkler system.
After resetting the timer she asked if I would look at a spot in her back yard that didn't appear to be getting watered. I ran through the zones and sure enough, one zone wasn't working. I grabbed my meter and took some voltage readings. I found voltage at the terminal at the timer for the zone in question and also determined voltage was in fact reaching the valve, but not activating it. I disconnected the wires from the valve and found the resistance was very low, not shorted, but quite low. A very quick and easy discovery but then I worried about locating a solenoid.
I was worried I would have a difficult time locating a solenoid for the valve as it is about 40 years old.
I left thinking I would have to order a new solenoid but decided it was 10 minutes before the local plumbing store closed so it was worth a stop and maybe I'd get lucky. To my surprise they have a universal solenoid that looked very similar so I rolled the dice and purchased it.
I ran home, changed clothes and grabbed my wife before heading back to her Grandmother's place. Upon arriving back at her home I installed it and the zone would now activate but would not shut off when voltage was removed by the timer. I disassembled the valve and found a lot of crud in the valve so the pilot bleed port must not have been able to bleed off the pressure and close the valve.
After a good cleaning and reassembly everything seemed to be functioning properly and I was able to put everything back together and call it a day. The worst part was the heat, it was 101 degrees while I was knelt down behind shrubs working on the valve box where there was absolutely no air flow at all.
Glad that job is done but also glad I was able to help her out. I sure miss my wife's Grandpa. He was a great guy and real salt of the earth.
Thanks for looking.
