zmotorsports
At this point as the engine bay is going back together I knew the car was only a few hundred miles from being due for an oil change and tire rotation.
While it was in the shop and on the lift I figured I may as well just go ahead and complete the next LOF service items now and then it should be good until after the first of the year.
I removed the battery, battery tray and lower air box to access the transmission filter and replaced it.
Next I reassembled the engine bay, dumped the oil, rotated the tires and drained the transmission fluid. Followed by refilling the transmission and engine oil.
Installed the engine covers and gave them a wipe down with Power House.
Once sitting back down on the ground I torqued all of the wheels to spec. and took her for a test drive.
It's nice to have that checked off the list of maintenance items, but to be honest, it may have been a waste of time as the valves were only off by a thou. I had two that were tight by .002" but all of the others were only tight by .001" from factory spec.
I also went much longer than the factory recommended service interval on this particular service. I generally follow factory recommendations to the letter but I know how this car has been maintained and I know they are all highway miles so it could go with a bit longer interval compared to a car that has a lot of city miles with stop and go traffic.
Thanks for looking.
Thanks for looking.
