Oil Drain Pans
Alright fellas… I’ve had it. I’m done with those crappy plastic oil catch pans that you buy at the typical national autoparts chain. I’m just done with them…
My typical scenario goes like this:
  • – I take three crappy plastic pans to the parts store and drain them while I buy new oil/filters.
  • – I come home, fill the crappy plastic pans with used oil, and fill the cars with the fresh stuff.
  • – I then stack the crappy plastic pans with used oil in a corner of my shop until I need to change oil again.
Sounds workable, right? The problem is, the crappy plastic oil pans  feature crappy plastic threads on their drains and these crappy plastic threads don’t hold up to the torque required to keep the crappy plastic pans from leaking all over my beautiful floors.
I’m so done. Cost is no object. This problem must be solved. Through searching, I’ve found these steel units pictured above. I’d rather have something that seals up, but I guess I could fabricate a lid for one of these things. However, the reviews online of these aren’t all positive.
I’m wondering… What do you guys do?
See Comments on the forum.
GMCGarage
I use crappy plastic pans, then pour into 5 gallon pails, and then when at about 3 of them, put on craigslist for the oil burning heating crowd. never had issues getting rid of the oil. Usually find free pails here and there too.
ChaseDE
Delaware
Unfortunately I have cats. Fortunately the big cat litter pails make EXCELLENT oil receptacles.
I use the cheaper plastic drain pans, then transfer.
I place an old towel on top of the pail after transfer and put the drain pan on top.
There is a guy here who fabbed a whole oil change cabinet for his garage which was pretty snazzy though.
madison069
Monroeville, PA
I have a 3 gallon plastic pan that is closed on the top, just have to remove the plug.
One thing I have notice is if I don't have the gasket/cardboard on the cap then the drain spout will leak. Otherwise I have no issues and mine actually resides above my wife's car in the ceiling when I don't use it.
rlitman
Long Island
I vacuum extract my oil into a 7 gallon container (an old forklift propane tank that has a liquid level gauge). I still use my funnel top oil catch pan for removing the filter from two of my vehicles (and for draining the top-side filter from my Subaru), but it'll take years before I fill it up again, as it holds around 10 quarts.
I still use these to take oil in for recycling:
The large lid makes them easy to fill and empty, and they seal reasonably well.
For transport, I happen to have a steel box with nice handles that perfectly holds two, and I've put newspaper on the bottom to catch drips. Before I had that, some rags in a milk crate served well to protect my car from the fact that no matter how clean you try to be, these containers will always carry some oil residue.
For me, my biggest concern is in transport. A mere quart of used oil spilled in my car is a recipe for an unwanted carpet replacement. I want a container, preferably close to but no bigger than 5 gallons, with a screw on lid that I can feel comfortable will not leak no matter what I do with it. And it has to be easy to pour into, AND easy to pour out of, without making a mess, so it has to have a lid shaped more like a spout and less like a drum head. It also needs to empty quickly, so re-using old 5 gallon paint containers with pop-up spouts wouldn't fly, because the cap is too small.
HOTRODPRIMER
Anderson,S.C.
Before the environmentalist decided to save us from ourselves my granddad drained the used oil in a ditch now we are more environmentally aware I use the plastic pans Ryan was talking about.
I also have a reclaiming station within 2 miles from home so the plastic pans with the screw cap is easy to pour out at the station. HRP
notadoktor
I use a Lisle oil drain pan (https://www.amazon.com/Lisle-17942-Black-Plastic-4-5-Gallon/dp/B000JFHMVQ/ref=sr_1_1?ie=UTF8&qid=1488386088&sr=8-1&keywords=lisle+drain+pan). I'm pretty happy with it as it's quite sturdy. My only complaints are minor, when I bought it there was a sharp burr where the mold halves came together but was easily removed with a razor blade. Also, the small turn down of the spout will drip a bit of oil after you've poured but I just take a shop towel and give the inside a quick wipe and it's all good.
As for storing and transporting oil, I wait to empty the drain pan until after I've put the new oil in and just reuse the container (I usually buy the 5qt jugs). I have thought about getting a 3 or 5 gallon bucket with a pouring lid but just haven't gotten around to getting one yet.
wretched73
I use the same oil pan and i like it.
I take all my used oil and put it in an old 5 gallon bucket with a god sealing lid from the Home Cheapo. Once full I leave it at autozone and they recycle the oil. Work perfect and i only have one bucket of used oil to watch out for
wes73
South Central PA
I use a plastic pan and then pour back into the gallon jug I just emptied into the vehicle. There are several farms around me that have oil drop offs that they use for their outside furnaces. I just drop off the full container.
vavet
Ashland, VA
I use the plastic pan and pour into the gallon or 5 quart jugs that the new oil came in. Our local transfer stations accept oil, filters, paints, and antifreeze from county residents. I have a plethora of Lowe's 5 gallon buckets. I bought a bunch when we moved to save the aquarium water so we wouldn't have to go through the pain of getting the water chemistry right again. We spent $20 on buckets to save a single fish that we paid $3 for. Maybe I should start using one of those instead.
CoogarXR
That's what I do. I wait until I have 5-10 of them full, and list them for free on craigslist. Somebody calls, arranges to pick them up, and I set them at the end of my driveway. I come home from work and they are gone. I don't have to deal with the mess or the empty bottles.
Mech55
I have 5 gallon buckets with lids that seal nice and tight. They stack nice in the corner until time to take them in.
Keel
LaLaLand
This.. I have a nice plastic one that seals nice if you wanted to bring it to the parts store to recycle it.. but I drain it into a 5gallon bucket.. and when a few are full.. the local shop with a waste oil heater thanks me.. dump in his tank and go home with the 5g buckets
R
Ryan
Administrator
Boulder/Koloa
Here's the one I have. https://www.amazon.com/dp/B0171QLC4S/?tag=atomicindus08-20
It has a o-ring in the cap so it hasn't leaked on me yet. I also like how it can be stored standing up which keeps the oil away from the cap. The only thing I don't like is the splash back when all that hot oil or trans fluid starts pouring out of the car.
Still crappy plastic... but the design looks better than what I use. I typically use these damned things:
https://www.amazon.com/dp/B000AMGYNA/?tag=atomicindus08-20
trainer
Northern Ontario, Canada
The problem is that we are still changing oil the same way they did 100 years ago.
I'd love to see the OEMs design a system where the oil and filter is contained in a replaceable tank that could be changed like an ink jet cartridge. The old tank could be returned for a deposit/ core refund and be recycled and refilled. The tanks could be designed so it is impossible to use the wrong oil.
Bryan Burns
Grayslake, Illinois
I bought this this made in U.S.A. galvanized steel drain pan in 2013 and I'm very happy with it. $12.67 and I got free shipping.
I transfer used oil from it to plastic jugs and drop the jugs off at the public works facility two blocks from work. They have an unlocked drop-off cabinet outside so I'm able to just drive up to it. Activity is monitored with a camera (according to a sign) to discourage contraband.
EOC_Jason
Bentonville, AR
I use the Flo Tool too, needed the capacity for my diesel...
I've seen the Hopkins on clearance at HD for $4 recently...
If there are any machine shops near you they always have lots of 5 gallon pails with the nozzles on the ends that they get way oil, coolant, etc, etc in... I would just fill up a couple of those then take them to the auto parts store or quick lube and let them drain it in their bins...
EOC_Jason
Bentonville, AR
If they are like ink jets then it would be cheaper to buy a new car than get a new oil cartridge... :lol:
Leaflessshadetree
Don't ask.
I use galvanized steel pans, had the same ones for years. One did get damaged a couple years back I don't recall the replacement being hard to find or expensive.
nes999
IL
Thanks, I have been looking for something just like this. Granted I want it for other he purposes than changing oil.
vettex2
Northern Ca.
I have one similar to that that is wider but not as deep.
I wish I knew where I got it. I'd buy another.
As it is now, I have 4 metal round ones , the aforementioned, another smaller version of the aforementioned and some hospital pans for a total of 10
dclassical
Like others have said I just use an empty oil jug to take it to Autozone. I have one on my way to grocery shopping, so I try to not wait and let them accumulate. I don't see buying something fancy for an oil change.
timl
If you have a local small airport, aviation oil comes in 5 gallon jugs with a big lid, go ask them for empty jugs, I use them and take the oil to walmart when I have several.
I also have a friend who has an oil burning heater in his hangar, so often would dump my oil in his tank, that was very handy.
The best I read here, was to list them for free on the Craigslist and someone would pick them up, that's brilliant, but here in my area in the NVA suburbs, so few people do anything for them self I doubt I would get any takers.
Milton Shaw
I finally figured out how to drain my drain pan into 5 gallon gas cans to take to dump. Put the gas can into a garbage can and it will catch any spills and keep can from turning over. I use a big funnel to help but until I finally figured out the garbage can tip, I always had a problem with the funnel and oil turning the can over making a big mess.
evintho
Santa Rosa, CA.
I use the crappy plastic drain pans. Once done I pour the used oil into 2 gallon containers provided by our garbage company and I set them out at the curb, along with the garbage cans. Garbage company picks 'em up, recycles the oil for us and leaves us new containers.
d.mcfarland
Western PA
You'll like it. They are strong and large. I however, wish they had a spout or something that would make pouring easier.
nes999
IL
I use them for training dogs to stand on them. The ones from Wal-Mart go to Hell after 6 months of use. Those looks much heavier built.
sberry
Brethren, Michigan
If I was a suburb 1 or 2 car kind of guy would really have a tuff time trying to change my own oil. Given the ability to go extended change could easily find a place to drain and change it for a decent price. I know a couple places, 1 a dealer got a great change special and they do a good job.
APEowner
Sunny, New Mexico
I use a variety of crappy plastic drain pans but I dump them into a 55 gallon drum. When the drum is full I take it to a buddy with a waste oil furnace who swaps it for an empty one.
Dr Stan
Owensboro, KY
That would be very nice.
In NE there was a recycle station run by the city that took solid & liquid recyclables and was quite handy. Here there is a recycle day every 6 months or so set up at the sports arena. Also very handy as they'll take stuff the auto parts houses will not touch, such as gasoline, diesel, paint, insecticides, etc.
paulsomlo
Northern Colorado
I use a Drainmaster, which I bought about 30 years ago. Sometimes I use it in conjunction with a Form-a-Funnel, but lately, I've just been holding the Drainmaster right up against the plug and using a Drain Plug Pro to keep my hands out of the way. The DM is small enough to hold it up there with one hand, and that way, there's no splashing, no misjudging where the stream of oil is going to go, and no intermediate containers. I take it to Autozone for recycle.
the GOAT
I'd love to see the OEMs design a system where the oil and filter is contained in a replaceable tank that could be changed like an ink jet caurtridge. The old tank could be returned for a deposit/ core refund and be recycled and refilled. The tanks could be designed so it is impossible to use the wrong oil.
Already been done
BearsFan315
Portsmouth, VA
i use the cheap oil drain pan, then put the used oil back in the 5 qt container fresh oil came out of, then take it drop it off a the local auto parts store and dump it. i keep a spare 5qt just in case.
never keep oil in the drain pan. i also use a funnel to ensure i do not pour it all over the place. works for me, and did not cost me anymore money. free container with every purchase !!
