The Mileseey XTAPE1
A few months back I gave a pretty glowing review of the Mileseey S50. Shortly after, they sent over their latest contraption, the $240 XTAPE1. I was supposed to get this write-up done months ago, but life did what life does and kicked the can down the road. Silver lining though, I’ve had a lot more time to live with the thing.
So… what do I think?
If there’s one thing that matters above all else with any measuring device, it’s trust. If you don’t trust it, it doesn’t matter how many features it has, your work is going to suffer. And the XTAPE1? It leans hard into what feels like witchcraft. Lasers, calculations, angles, stored data… it’s a lot. And magic, at least at first, is hard to trust.
On paper, the thing is absurd. It’s got a traditional 12-foot tape built in, but then it layers on laser measurements, continuous tracking, area and volume calculations, layout tools, angle displays, point-to-point math, indirect measurements… it’ll even split a line into equal segments and store everything you do in an app on your phone. It reads like something built by an engineer that got bored and decided to throw the entire toolbox into one device.
And here’s the kicker, most of it actually works. Really well.
But none of that matters if you don’t trust it.
Early on, I was cutting sheet goods using the XTAPE1 as my guide. I’d set the measurement, mark off the laser, and then just stand there staring at the line like it was about to betray me. Inevitably, I’d grab a traditional tape, double check it, and make a second mark just a hair off from the first.
Every single time, the XTAPE1 was right. My “backup” mark was the one introducing error.
That happened enough times that I started to let go a bit. Slowly. And that’s really the story here. Whether it’s point-to-point measurements, indirect height, or just basic tape work, this thing is incredibly accurate. But you have to give yourself time to believe it.
Once you do, it’s a game changer.
It’s quicker, easier, and strips away a lot of the hassle from measurements that used to require a second set of hands or a bunch of extra steps. The battery life borders on absurd, I haven’t touched a charger in over two months, and it just sits there doing its job without ever making a fuss.
There are plenty of videos out there walking through every feature in detail. I’m not going to rehash all of that. What I will say is this: if you pick one up, take the time to learn it, and more importantly, give yourself enough reps to trust it.
Because once that switch flips, this thing is legitimately awesome. Buy yours here.
And because I know someone is gonna ask, here’s a quick list of all the shit the XTAPE1 is capable of:
Traditional Tape Measurement:
Twelve feet of honest steel hiding inside the machine, marked up like a prison wall calendar. Big hook on the end with a magnet strong enough to grab onto anything ferrous and refuse to let go.
Single Length Measurement:
Point the green beam like a weapon and tap the blue arrow. One shot, one number. No ceremony. The distance appears instantly, cold and factual, like a verdict handed down from a judge who doesn’t care about your excuses.
Continuous Measurement:
Now we’re moving. This thing updates every 0.3 seconds as you walk, pace, stumble, or lurch toward your target. Numbers rolling like a slot machine. No waiting. No second chances. Just constant feedback while you try to keep up.
Area Calculation:
Square footage for the impatient. Shoot two lines, tape or laser, doesn’t matter. Lock them in and the machine does the math while you stand there pretending you were going to calculate it yourself. Perimeter, square feet, square inches… all laid out like a confession.
Volume Calculation:
Same deal, but now you’re thinking in three dimensions. Length, width, height. Add the third number and suddenly you’re measuring space itself. The device spits out volume like it’s nothing, while you nod along like you saw it coming.
Stake Out:
This is layout work for people who don’t trust eyeballs. Set your points, walk the line, and let the machine keep you honest. No drifting. No guessing. Just precise, repeatable marks in a world full of sloppy geometry.
Live Angle Display:
Tilt it, twist it, spin it like a man losing control. The green laser becomes your horizon and the screen tracks every degree in real time. It’s like carrying a digital level that never blinks and never forgives.
Point to Point:
Two targets. One calculation. The XTAPE1 figures the distance between them, your position, and the angle tying it all together. Three numbers on the screen like coordinates to something important… or incriminating.
Indirect Height:
You can’t get there directly? No problem. Measure the hypotenuse, grab the angle, and let the machine tell you the horizontal distance. It’s geometry for people who skipped class but still want to win.
Indirect Length:
Top and bottom readings, two hypotenuse measurements, one angle tying them together. The machine stitches it all into a vertical dimension while you stand there wondering why you ever trusted ladders.
1/N Line Split Function:
Set your interval and let the tape run. Hit your mark and the machine breaks the line into perfect segments like a drill sergeant dividing recruits. Clean splits. No guessing. No drifting. Just order imposed on chaos.
If you are interested, you can get yours here.
R
Ryan
Administrator
Texas/Hawaii
Forgot to mention this in the article:
Mileseey hasn’t paid me a dime. My opinion isn’t for sale. They did send the XTAPE1 over for free, but that’s where the relationship starts and ends.
If you’ve got one and it’s giving you trouble, or you’ve found flaws, quirks, or things that don’t add up, post them. Good, bad, or otherwise, it’s all fair game.
And I'll do the same... But for the past couple of months, mine has been nothing short of perfect really.
signcrafter
I bought the s50 after your post here and absolutely love the thing and use it all the time. I will have to look into the Xtape1 more but reading the amazon listing I'm not seeing as much value for 240 dollars as I did with the 99 dollar s50. Looks like an interesting tool and maybe I didn't look into enough to see what all it can do.
APEowner
Sunny, New Mexico
Interesting. My concern is that I do the type of work where I'd use a tool like this sporadically. I'm wondering if I'd have to relearn the thing after not touching it for 8-10 months and if that relearning would negate any benefits.
R
Ryan
Administrator
Texas/Hawaii
The tape measure and the laser measure function? No. You would not. It's very straight forward.
The other more advanced features? Maybe so...
I don't really use the phone app that much, but I did make a house floor plan with it and worked great... It took some learning to do it though.
signcrafter
The floor plan feature sounds interesting. I just measured a house for LVP flooring in the whole thing besides bedrooms and entry ways. I used the s50 to get most of the measurements and just wrote them on a crude drawing. A floor plan wouldn't really be any more useful but would look a lot nicer. Would be nice to be able to do a floor plan when starting a job, especially for getting a permit.
TheFixer
Hey @TheFixer , @Slowbuilder - what ya'll think?
As you may have noticed, I've been building a 56x36 polebarn with a steel mezzanine over the last year (construction of the building over the last 6 months). I've used the S50 a LOT...here's some thoughts:
- It is awesome for measuring long distances extremely accurately - I used it a lot while constructing the mezzanine, getting the posts in the correct locations, making sure everything was square etc.
- It's great for measuring the distance TO something (e.g. - how far am I from that wall), or how high is the ceiling)
- It's not that good for measuring the distance OF something (for example, if you need to measure the distance from the end of a joist to the other end, you need to have something to aim at - I have ended up using a clamp to fasten a piece of card to and to be honest using a long steel tape would have been easier.
- Same in measuring things like the width of a cabinet, or the position along a 2x4 you need to cut. You definitely need to still make sure you have a simple old-school tape with you
I'd say that it's definitely best for construction, where you are measuring 'inside' of things (you always have a wall to point at), or at planning where something will go.
It sounds like I'm being negative - I'm not; it has been really good and allowed me to do a lot of work on my own/faster when I didn't need someone to hold the dumb end of a tape. I REALLY like the accuracy (the 'fit' of my mezzanine in the building, and the fit of cabinets etc between posts is extremely tight, and I trust the M20 down to the 1/16th inch, even over 30' or 40'.
Usability is generally pretty good, except that I wish that when you selected a 'mode' from the circular menu it was 'sticky' (e.g. I really like the continuous measurement mode, second on the menu, but every time I turn it on it defaults to the first option. There might be a way to change that, but I've not found it). Battery life is great.
Thanks for organizing the giveaway!!
Grant Gunderson
Bellingham, WA
Well ****. This forum got me again. Just ordered one with both the standard and metric cartridges as I’m right in the middle of building out my shop and gotta run electrical conduit plus air lines, and then build a bunch of counter tops and cabinets (all my wood working tools are metric) so we will see how it does and if it’s a replacement for my Fastcap tapes.
R
Ryan
Administrator
Texas/Hawaii
I think it's too big and heavy to use as a carry around tape measure for job site work and it won't replace my regular tapes for that... But, it has replaced my regular tapes at my workbench and MFT. It's fantastic for processing sheet goods.
I need to explore their catalog a bit. I love the S50 for taking room measurements and basic laser work. The form factor is just perfect. And I love the XTAPE1 primarily for sheet goods, lumber, etc... basic stuff.
I wonder if they sell a smaller tape based unit without all of the complexity that could replace a traditional tape? The XTAPE1 is a great total solution, but I almost feel like an S50 plus a smaller, more simple tape based system would be even better for me.
TheFixer
Agreed - I've found myself carrying both the S50 and a 35' steel tape continuously as I work on the internal fit-out of my workshop. If the S50 had a tape built in that did the basics, that would have been awesome (or some other way of measuring to the 'end' of something.
For example - I need to cut a steel joist or decking to exactly 23' 4" (having just used the S50 to measure that distance to the wall).
I then either need to use the tape or use a clamp to fasten a piece of card (as a target) to the end of the steel.
signcrafter
What are the benefits of it over a regular tape on sheet goods? Just having a laser to mark your line? I'm guessing you use it for breaking down sheet goods with track saw and I do this a lot also. Not sure if I'm sold if it's just the laser but if it does something else I don't know about I might have to look more into it.
R
Ryan
Administrator
Texas/Hawaii
Traditionally, I’ve used one of those lay-flat FastCap tapes. It’s been solid. No real complaints.
But I’ve found the XTAPE1 to be more accurate and more repeatable, and a lot of that comes down to simple physics. The head on the thing is heavy. You pull out six feet across a sheet of plywood and it just sits there. No creeping, no shifting.... it's hard to knock it on its side. That alone makes a difference. The weight is really, really nice.
Then there’s the laser. You can choose where your mark actually lands, front edge, rear edge, or dead center of the laser line. Set it to the front or rear edge, use a sharp pencil, and you can get really precise, really consistent marks.
For me, it’s just faster and easier. I genuinely like using it.
I’ve mostly ignored the deeper feature set, not because it’s not useful, but because I prefer the simpler form factor of the S50. The XTAPE1 does a lot more, and I’m sure I’ll dig into that over time. Right now, I just don’t need the extra complexity.
Grant Gunderson
Bellingham, WA
Ok so I ordered one with both the inch and metric models. Didn’t want to wait for the dual version.
First try I was like what the hell. This thing ain’t working worth a damn. Even with my mid age eyesight I can tell that’s not matching the tape. So I turned it off and then back on again and it’s spot on
And it’s now working perfectly. I then actually read the F’ing manual. When you need a manual to read a tape…(there has to be an apprentice joke there) you know it’s overly complicated. Turns out you can change if it reads from the laser cross line or the **** of the unit. You can also change how it reads the display as well. Plus you can change the colors too. Whatever. Lots of gimmicks on it I’ll never use… it’s also really damn bulky, but I can actually read it so it’s going to get used a lot.
IMG_9161.jpeg I gotta say if you’re under 40 it’s probably not worth the cost. If you’re over 40 and you are resistant to getting readers when you know damn well you need them (like me), it’s pretty damn nice. Way easier for my eyes to read than a standard tape. And yes I know readers are cheaper…
At some point I’ll check out the phone app and see what else it can do, but I don’t need it to calculate volumes or anything else that it does… that’s all easy math. I’d love it, if they just came out with a dead simple one with just the display and less buttons / modes. I’d prefer simple and more compact, but I really like being able to read it. Getting old *****.
I did see they make the DT20…. That might be the perfect combination and it’s only $70
