Tips & Tricks
So I’ve been following Rothaus’ build thread on his “Airboxer Garage” and stumbled upon his simple little trick to efficiently capture left over oil residue. Not only is it great for almost finished oil canisters, but it would also be nice for funnel storage.
Anyway, the whole thing made me think of simple tips & tricks for the garage that you don’t see every day. Everyone has one… What’s yours?
See Comments on the forum.
mgilde13
Re: Tips & Tricks
Here's one that I've been doing for years when siphoning old gas out of lawnmowers, snowmobiles, atv's, etc. What I do is I shove an air tool fitting into the end of the fuel line then shove it the tank. The reason I use a fitting is to weigh the end of the line down so it stays on the bottom of the tank, allowing me drain it as far down as possible. Once the line is in the tank, I then place a shop rag on the opening and hit it with light burst from the blow gun. The air pressure pushes fuel through the line causing the siphoning process to begin. So there you have it. An empty tank and no gas in your mouth.
carhunter
southern Ohio
Re: Tips & Tricks
I use this nifty bottle drainer from Oil Saver. Hangs on the side of my oil storage cabinet.
http://www.amazon.com/dp/B008LFKZ9W/?tag=atomicindus08-20
You can fit 5 quarts at a time, or jugs fit sideways. Amazing how quickly you can recapture a quart of oil. Since its mixed brands and viscosities, I only use it on lawnmower or a beater car.
Only drawback is that its open to the atmosphere, so probably a good idea to keep the tray covered.
Oldbear
Linden, Alberta, Canada
Re: Tips & Tricks
Sorry I don't have pictures, but I use old speaker magnets on my drill press to catch filings as I drill.
Gas line antifreeze in my seasonal fuel tanks each year to help remove water from condensation.
A comb to hold finishing nails as I hammer.
And old *****-hose on the end of my shop-vac to find small dropped parts.
marty_p
SE LoUiSiAna
Re: Tips & Tricks
I love ideas such as these, and usually the simpler the better! :thumbup:
If only I could remember them all to put them in practice... :dunno:
Always_Thinkin
Illinois
Re: Tips & Tricks
Ever spill small finish nails or a small hardware organizer drawer and small hardware goes flying across the floor? Turn a sandwich baggie inside out and insert a magnet. Use the magnet to pickup the steel hardware/nails. The turn the baggie right side out and pull the magnet off of the bottom of the baggie. Now dump the contents into your hardware organizer or storage box.
Imcrazy
N. Texas
Re: Tips & Tricks
I've seen a variation of this where you put the magnet in a ziploc bag. It makes it easy to clean the magnet off when you are through.
Jhoff310
Perrysburg Ohio
Re: Tips & Tricks
Tampons--for removing gas/oil from a tank, they will hold ALOT
Old silverware dishwasher basket--holds an asst of screwdrivers, files or whatever else you decide to use it for.
Jeff
uniballer
bedford, va
Re: Tips & Tricks
I do metal folders coffee can with four hole in top for oil bottles. My dad showed me in the 80's.
BigAl62
suburbs of Chicago
Re: Tips & Tricks
When disassembling small stuff, I put the parts in ice cube trays and fill from left to right so I remember what order things go back together in (getting old *****, I am getting more forgetful!).
Charles (in GA)
50 mi south of Atlanta
Re: Tips & Tricks
I've drained oil bottles for years. I do it to keep a little bit of pollution from the landfills. I have a plastic 5 qt ice cream bucket with a flat plastic lid. I used a hole saw to cut holes in it and just upturn the oil bottles in the holes, they help to keep the dust out of it. Weeks later the next oil bottles go in there and the old ones are done draining and go in the trash. I use this in a old Sarlo bicycle wheel mower I use for mowing edges and rough areas.
At work aircraft turbine oil comes in metal quart cans. After emptying them into an engine, we have to put them in a drain rack that drains into a used oil drum. Again this is to prevent the oil from getting into the landfills.
Charles
Charles
Grazz256
Re: Tips & Tricks
This combined with a digital camera (for taking pictures, not sitting in the closet..) and an area on your work bench for the large parts and you should be good to go.
Cheers
Stephenw
Utah
Re: Tips & Tricks
Many replacement parts come with packing plugs. I like to save these plugs for future use. They are great for plugging holes during disassembly to keep dirt and moisture out of a component.
toolfanatic
Ireland
Re: Tips & Tricks
I am a great fan of neodymium rare earth magnets, even the smaller ones are very useful- I tape one around the chuck key to keep it at the pillar drill where it belongs. I also taped one around the handle of the push stick for the router table and table saw- that way they're always to hand. I use one from an old pc hard drive to recover screws and nails from the workshop sweepings- I then use my very own child labour (daughters aged 6 & 7) to sort them for me, which they love (great while it lasts!).
goodysgotacuda
DFW
Re: Tips & Tricks
Dont have time to wait for every last drop.:dunno:
I agree on a home use level. At a dealership level, at BMW, we got oil by the quarts for cars. I drained every bottle I used. I ended up with about 1-quart of fresh new oil a day for my own use. I quit more than 2 years ago and still have BMW in my Jeep today. In volume, it works well.
Johnny chaos
upstate NY
Re: Tips & Tricks
The plastic top from a rattle can works great for holding wires to be soldered. One slit on either side of the top and slide the wires into each, the open space in the middle is where you solder.......I also pull the sprayer nozzle out of the old used cans and throw them in the toolbox for later use for when one gets clogged, lost or broken.
Always_Thinkin
Illinois
Re: Tips & Tricks
An idea that I seen here on GJ and recently installed on my workbench is a handy way to protect your workbench from paint/staining projects. It is cheap and easy to install. It is a vinyl roller window shade mounted to the end of the workbench. Before you start a painting project, pull the vinyl shade across the workbench top. Let the paint/stain spills on the shade dry. Then retract the shade and it stores out of the way and ready for the next project. I bought the shade at Walmart for under $8 and the mounting bracket kit for $1. After trimming the shade to fit my workbench the area covered by the shade was approximately 2.5' x 5'. I can take pictures if anyone wants them.
Jhoff310
Perrysburg Ohio
Re: Tips & Tricks
old hacksaw blades with a few washers behind screwed to the wall is a great tape measure holder
Jeff
MetalMangler
Upstate NY
Re: Tips & Tricks
That is genius! I had thought of something like a roll of butcher paper (same idea as the Dr uses on the exam tables) but your idea is perfect. Shouldn't bleed through, reusable... Thank you sir! :bowdown:
MM
boilermanc
*******, GA
Re: Tips & Tricks
The plastic top from a rattle can works great for holding wires to be soldered. One slit on either side of the top and side the wires into each, the open space in the middle is where you solder.......I also pull the sprayer nozzle out and throw them in the toolbox for later use for when one gets clogged, lost or broken.
excellent! always have a challenge with the wires staying together!
Always_Thinkin
Illinois
Re: Tips & Tricks
Great tip! It will even catch any excess solder that may drip. I had made a tool to accommplish the same thing but it cost more to make and was a little to heavy for smaller automotive wires. It was a 1.5 inch diameter metal washer with a large hole in the center. Then I drilled and rivoted two small alligator clips to the washer. Again, great idea.
wafrederick
Holton,Mi
Re: Tips & Tricks
I know someone that does that,saves the oil bottles and takes too much space.I tell him it is a waste of time,I pre empty them ahead of time if I have time.
bigbubba
Poplar Bluff Mo
Re: Tips & Tricks
Jeff
Not shop related but.......My wifes uncle,Myself and his son were out gigging one night,We hit a rock and slice a 8-10 inch gash in the bottom of the boat! The only thing we could find was a box of tampons in the dry box,Stuffed them in the hole and after a few seconds the bilge pump was gaining on the water.After a few minutes the boat was almost dry again! We headed for the boat dock but it seemed to be working so we went back to gigging(Beer was involved in this decision) Don't know how long it would last but i know it's over 3 hours:bounce:
winmck
Richmond, Tx
Re: Tips & Tricks
Now that's a tip I could use!:bounce:
bigbubba
Poplar Bluff Mo
Re: Tips & Tricks
We also ran up on a car wreck when my son was still in pullups,The lady had cut her head and we had nothing to stop the bleeding.Took a pullup and turned it upside down and put it on her head like a sock cap,It worked till the ambulance got there!
Inky Ford
Southern California
Re: Tips & Tricks
I screwed a Victor rat trap to the wall of my garage and use the "clip" to store my leather work gloves. Lots of other applications.
niget2002
Josephine, TX
Jeff
Tampons and duct tape can also patch an oil leak on a Harley long enough to get to the next town.
Sent from my DROID RAZR using Tapatalk 2
