^ I have no idea.... it looks like ebay is putting a "block" attribute on all of the image files posted.
Some ebay sellers resort to other means in an attempt to "protect" their scans of out-of-copyright material they've lifted from other sources, which I find laughable at best.
The "PrtSc" key still works, so it really doesn't matter. ;)
Great work Don! (y) Cool booklet.
Page 8 actually mentions Wright Field ratchets. Was there any known documentation on “Wright Field” tools prior to this?
I know very little about Wright Field tools. I refuse to go down that rabbit hole.
This plain steel but highly polished pair of diagonals arrived in the mail yesterday. I really didn’t like my rusty pair. When was this handle pattern used? A catalog search was inconclusive.08EE5880-E5BF-44C0-B1F0-99F8E8EEDFB4.jpeg376BDFC4-25C3-438C-90B0-3D78BCE8D9F6.jpeg35C24EF5-7AE2-4293-B0B2-6BB5CD119709.jpegA4B693DA-892F-4E28-BEBA-362E3909FE72.jpeg
Smokeshow69
That’s the Danielson “Union Jack” handle pattern. I don’t know exact years they switched but I believe it was towards the end? That pattern is present on Proto la pliers. I also have a dual marked pliers with the same pattern.
I ground the point off my new punch. It’s quite a bit shorter than it’s factory length. Unlike most of my early punches and chisels there doesn’t seem to be a date code. With the round o it has to be pretty early.
I had a 1” deep socket in my wartime 1/2” drive set that I wasn’t sure if it was plain steel or worn chrome plating. I spotted this dark finish example on eBay and bought it to replace the suspect one.
-Don51E9FA0B-DE9F-4A1A-99E9-70452DC88B6E.jpegF2BC679C-4965-4D51-AD32-D960E637F45E.jpeg
Upon close examination of my previous socket, I noticed a bit of chrome peel so it had to go. The two sockets are quite different in construction and marking details.082A70CE-EF03-4547-956C-8A5DD602113D.jpeg4928AD33-1247-45D4-877D-7D0A286E6337.jpeg
Another Plomb tool that arrived yesterday was this 86A 7/8 chisel with a 1” cut. I’ve never been satisfied with the Kraeuter chisel in my WW2 machinist’s set so I’ve been on a mission to find one close to the specified length of 9”. The Plomb one is listed at 8” so probably within the plus or minus allowance.A67C5576-CBE7-4890-BC3D-C2B40ACA1CB4.jpeg5EF5AED3-437F-4AD4-8433-7BD4B563D9C9.jpegI’ve started the dressing up and sharpening procedure but ran out of time.A30E1049-A31A-4386-8A79-3C0719613FCA.jpeg888620BF-49D9-4E82-B936-94548FB2B80B.jpeg
Old pictures C3D33258-569A-4351-8BD4-3780484B2853.jpeg2324CCA5-EAD8-40AB-888D-D1A9581793FE.jpeg8C314772-AC5A-408B-B9C7-0DF586E84CF8.jpeg9986CEFB-EA25-49C0-AF05-202E680FBC38.jpeg
catongw
Hi Everyone.
This question probably been asked over and over but I went thru first ten pages and last ten pages of the thread and didn't find my answer so just gonna ask.
Did the wrenches come from the factory painted like that or did the original owner do that? If factory is there some significance to the colors ?
Thanks for the help .
catongw
Here's a couple more. I "inherited" a stash of tools from a little old lady(95yo). These were her dad's.
MR.X
from right to left ( all are marked Plomb)... 1. is is a Douglas. Number 2 & 3 are 40-b-4175/6 and 4177 or something close to that, I've seen the same tools made by MAC with the same #'s. The yellow tinted one, which I never would have guessed as a plomb by the finish is also a Douglas contract " K65 something. The 3/8 extension is one of those PWA 1396's that are alittle more common in Bonney. And the one on the far left is a 20's era KInner....H9 maybe? I'll try and figure out the exact numbers.
Provincial
Near Salem, OR
Thanks! I think Plomb made all the Kinner tools, since they were located so close. We tend to think of tools like those being used on aircraft engines, because of access issues, but airframes also had access issues. Hence the Douglas ID's. Even the DC-3, which was designed with a major emphasis on maintenance, had some access issues.
If you run into tools with GT- prefixes, they are likely Grumman. I have a wooden box labelled "Operational Squadron Special Tools for Grumman F6F Airplanes." The label has a list of the contents, so there is at least some reference information.
Sanny81
New Jersey
Nothing special but found this today at the Florida Flywheelers show and loved the style a previous owner engraved their name.
MR.X
Nice! What are the numbers on them?
Far right is K-32305. Next two are the 40b-417X's. The gold tint one is K-65-3084-3GT. Then the PWA 1396 and the far left is a H9 Kinner. I added a pic of a 2nd K-65-3084-3GT that I have here. Also a pic of the Kinner.
