Harbour freight sand blasting cabinet
shayan
Hi guys! New to the group
I just fully modified my sand blasting cabinet and it’s now worst than it was !
I’m wondering if my gun is defective, when I press the trigger a ton of air comes out of the trigger pin?
It ***** the aluminum oxyde on and off
Suddenly a bunch comes out and then it stops
When I press the trigger the first 2 sec works the best?
I tried running everything from 60 to 120 psi and tried both nozzles
I’m thinking it’s the gun and I’m about to order the model with the pedal
But before I do i would be appreciated
shayan
Here is the gun setup
csp
Franktown, CO
Air should not be coming out of anywhere but the outlet of the gun. That issue needs to be resolved before any others are addressed. They may go away once you have proper airflow out of the gun.
shayan
So first thing would be to replace the gun?
shayan
Do you guys see anything else wrong with my setup? And what psi should I be running ?
alfadan
Augusta, ks
Many replace that gun anyway. There is a company that sells one with an angle to the media inlet that is better for flow to pick up media.
Surging is due to inefficient flow or wet media.
Jeff Ivers
Oklahoma
You should not have media coming out of the bottom of the cabinet requiring a bucket to catch it as shown in picture 2. You have changed from a siphon feed to gravity feed. You may have an obstruction or reduced flow in your gravity feed mechanism - pics and details of how you constructed it would help. Others have already addressed your gun issue. In addition, how much vacuum are you subjecting the cabinet to - too much could impact media flow. Finally have you experimented with adjusting the valve on your gravity feed mechanism?
supratreo
elk grove, CA
i think your thinking of "the tacoma company".
looking to do their mods myself.
shayan
Could you link the company, im looking for a non Chinese one
shayan
Thank you for your input
the bucket was temporary, I had just finished the setup and apparently I forgot to silicone a small corner, that issue has been addressed
I’m using 3/4 inch pipe on the bottom , I don’t see any restriction issues 🤷‍♂️
My vac setup is pretty strong, but I did try to fully open the vent on the side and it made no difference
PoorUB
Fargo, ND
In the picture of the bottom of the hopper, put a shorter pipe ****** between tee fitting at the hopper and the air bleed valve, the ball valve pointed up. Put a close ****** in and try it again. You might try almost close off the bleed valve. You don't need much air going into that valve, just enough to add some air into the mix to keep the media flowing. Too much air and you lose suction on the media.
Jeff Ivers
Oklahoma
What is the inside dimension of the area of your gravity feed mechanism where the flexible hose attaches? I have attached a pic of my assembly that works quite well.
shayan
If I understood correctly I’ll change two pieces
The one under the hopper and the one going to the ball valve
What do you mean when you say put a close ****** ?
I did try playing with the ball valve (from 0% to 100% in increments of 5% ish )
shayan
I’m using 3/4 inch galvanized pipe
And the hose is 5/8
I would have to mesure the inside dimension of the plastic fitting
But it does not look smaller than the setup
You posted
alfadan
Augusta, ks
A close ****** (as in 'gee that was close!) Is a short ****** with no non -threaded section in the middle.
PoorUB
Fargo, ND
Yep, I guess the tee fitting at the bottem can be a elbow. A close ****** is the shortest ****** you can find. So short the threads run into each other. There might be 1/2" between the fittings when you get it screwed back together.
shayan
What would you guys recommend? A trigger gun or one with a foot valve ?
I would prefer finger trigger ( if so what model cdn would be best?
I’m using a 90 gallon air compressor so I have a lot of air
alfadan
Augusta, ks
I use a trigger gun which looks like the above. I can get a little tiring to the wrist during long sessions, but I take breaks.
If you get pedal later, you can always ziptie the trigger down.
shayan
Good idea
Should I get the 4-8 cfm or 10-15?
I don’t know how to calculate that
Jeff Ivers
Oklahoma
And the hose is 5/8
You posted
No way to know the inside dimension without measuring. May not be your problem, just something to check. Keep in mind what the underlying design of the gravity feed is. The media falls into the down pipe and some of it will "fall" into the horizontal pipe that goes to your gate valve intersection. Visualize how far the media will extend into that horizontal pipe on its own. From there, the air flowing through the gate valve and into the pipe to the gun creates a siphon feed to pull the media up the hose to your gun.If the media is not near your air flow, it is hard for the siphon to work properly. Notice my gravity feed is built with the "close" ****** others have referred to.
Also, many think the gate vale has to be vertical, but this is not the case. Smaller gate valves actually are more adjustable on air flow than large gate valves.
Finally, with regards to the gun, when I modified my blast cabinet, acquired used, I went with the Eastwood gun and foot control. I much prefer this to the original gun. My build, with more info, is documented at https://www.garagejournal.com/forum/threads/blast-cabinet-improvement.310730/ .
rmmiller
Kennewick, WA
I installed the TP Tools upgrade kit before I ever used mine, works perfectly.
csp
Franktown, CO
That looks all fuckered up, why are you trying to draw the media from the bottom of the hopper like that?
It's a helluva lot more efficient than the POS siphon setup the HF cabinet comes with. Actually works great once you have it dialed in and you can blast at lower pressures.
545_days
Texas
3/4" pipe might be a little too large for your gun. In order to **** up the media you need velocity in the pipe and larger diameter equals less velocity. Sizing the suction line to entrain heavier than air media is a balance between pressure drop (pipe too small) and low velocity (pipe too large).
jdepiero
NE, Ohio
I also installed the TP tools upgrade kit. No issues. I also added a couple of flood lights inside the cabinet.
Benw455
WV
I am on my second TP tools **** Blast cabinet. Sell what you have and just buy one from TP tools instead of trying to fix what you have. You will be happier in the long run. JMO
FredWanaker
NorCal
I don't know what changes you have made since this thread began. You cannot pull from the bottom using a gravity feed with a system that was designed for a siphon feed. You need a good quality siphon feed. Also the media you are using is VERY abrasive. Choose your media based on what you will be using it for.
This siphon feed is from Metal Finishing Supply Co in Brookfield Wis, but many media places sell similar. I got mine from Temple Associates but they have been sold to another company now so I don't know what they have. Also with most of the HF units, be sure to reseal all the joints or you will forever be cleaning up leaky media. Get some quality gloves too because the ones with the HF cabinets don't last. Also consider having a custom floor cut for it because those bend and fall apart quickly too.
The flexible hose sits above the media. The right side of the metal hose goes to the gun feed. when the gun siphons air, that air is pulled down the flexible hose and enters the steel tube near the bottom. That means the air only needs to lift the media an inch or so before it enters the air flow. The way you have yours now in your original photos, the air siphon has to lift the weight of a column of media feet long, and fight the hose resistance too.
see https://www.garagejournal.com/forum/threads/blaster-cabinet-media-flowing-like-a-wave.490525/ or https://www.jalopyjournal.com/forum/threads/hf-blast-cabinet.1052821/
