Vintage Grinder Sticker Reproduction
LSUmAniac
Baton Rouge
Here it is.
I used a high gloss polycarbonate lamination. Very durable and has a nice gloss finish.
Dude that thing looks sweet, this grinder is gonna like a time capsule when this lable is slapped on, definitely gonna set the whole project off. Thanks again sir
Magillg
Phoenix, AZ
Matt do you have any of the power panel decals? If so I would like 3. Also a craftsman motor sticker. Are you still not charging for this? Thank you!
11b30b4
GA
Matt, you need to rename this thread to the Vintage Tool Decal Reproduction IMO. Keep up the amazing work.
mattblast
Bridgewater, NJ
@mattblast you are a master. These are awesome.
Thank you.
Here is another for the same drill press.
Craftsman 103.24500 drill press model number label. Printed and embossed aluminum to match original. My embossing machine is not exactly the same size, but very close. This is one of the rare situations where I have a physical tag rather than just a photo.
This one is laminated with a high gloss polycarbonate.
mattblast
Bridgewater, NJ
Dayton motor label reproduction for a South Bend drill press restoration. This was especially tricky to design with the heavy wear.
Usually I only have a photo to go by, but this time I had the old label mailed to me. Literally had to take a 10x loupe to the tag to make out the missing details.
mattblast
Bridgewater, NJ
Cincinnati Long Arm Buffer/Grinder Badges for a grinder restoration. These were redrawn as vector paths then printed, laminated, cut, and applied to aluminum sheet that was then shaped and punched.
Before:
After:
mattblast
Bridgewater, NJ
Reproduction tag for 7” Delta Rockwell grinder
Just noticed I made a mistake on this label that I made last week!
Before:
After:
Let me know if you prefer posts with thumbnails or full size images.
And I’m sure you’ll see my mistake!
BigTexasYardSale
Texas Gulf Coast
A beat up old sticker on a newly restored grinder makes it look bad. Many restorations require that the label be removed (and destroyed in the process) to repaint. When I restore a grinder I go all out - sandblast, paint, new bearings, replace cord, replace rubber feet, etc. I want my old grinders to have no problem lasting another 20 (or 40) years of heavy use before they look worn out.
Besides the old label my restorations look new.
Sometimes I need to remove the old label to sand and paint and sometimes the old label is damaged and needs to be replaced.
Here is a recent Baldor 3/4 HP from 1978 that I picked up for $200 a few months ago and is undergoing a restoration.
Solid grinder but it was heavily used and ready for a full restoration. This requires that I remove all the old stickers and sand blast it.
Here it is partially restored. Only new parts are the bolts to attach to the stand, the bolts to attach the polycarbonate sheets and the new labels. I still need to attach nameplate and switch cover which I ordered new from Baldor.
Baldor also sells the adhesive labels but they are overpriced in my opinion so I made them myself. And besides, Baldor won't sell the UL label.
These labels were drawn on the computer using the old label as a template. I scanned the old label in on the office copy machine then used vector based drawing tools to make a perfect replica. These labels are within 0.01" of original.
I print them on silver or white high performance adhesive vinyl using solvent inks then machine cut them to size (the cutter automatically rounds the corners). The hard part is creating the electronic version of the label. It can take an hour or two for complex ones. The printing and cutting take just a few minutes.
It's actually no more effort to print out 8 then I have a few extras in case I mess up.
These are unlaminated so they are damaged with alcohol based solvents but are water and light resistant. For more durable labels I add a high performance clear laminate prior to machine cutting. That does complicate the cutting process as the machine needs to re-orient the print origin but then the labels are impervious to chemicals.
Here's one I did for a craftsman grinder last year (this is the spare one that didn't end up getting used). This one took about 90 mins to draw.
And some for another machine I'm restoring
I use professional sign making software to do the layout (FlexiSIGN) which allows for fast and accurate drawing in vector format and can import and export EPS and PDF files.
All these labels (except the yellow/black ones) are extras that I don't need anymore. If you can use a any let me know and PM me your address and I'll send them.
I may regret saying this but I will also make any adhesive label for a grinder for free (at least until I get overwhelmed). If you need one post up a photo and I'll let you know of that is one I can make.
Beautiful work. Now that's RESTORATION, just like original.
frichard
If you are still producing Block Grinder decals, I would like to order one.
Coolerman
Paint Lick, KY
Mattblast, I am blown away with your work!
I am restoring a benchtop Craftsman 150 Drill press Model 103.24521.
I am in need of the motor decal. You have already done it for someone here, but mine is a 1750 RPM not a 3450 RPM. Here is the only pic I have of it:
I did not paint my motor in the OEM brown colors. It is RED. If possible I would like the background of the decal that is shown as brown in the above pic to be black to match my paint scheme better.
PM me. I also may be interested in the Craftsman 150 head band you posted. It would match my paint scheme much better than the OEM head band.
GJ'er
Unreal! I recreated a model label for a drill press I have been restoring, and I thought I have gone way too far down the rabbit hole but this is on another level.
There are levels to everything folks and this right here is on a whole other level.
mattblast
Bridgewater, NJ
Here it is. I couldn’t get the position perfect due to the angle of the photo but this should be very close.
Before:
After:
poeseph311
Thank you.
Hi @mattblast; your work is amazing@. Would you be able to make me one of these model number labels but with "103.24530"? And a Headband for the 100 series drill press? I see you have made one for the 150 but the 100 is slightly different shape and doesn't say "Craftsman" on it.
mcb74
Hi, would you be able to do up more stickers to sell? I have a 8107w that I’ll be restoring and will require new stickers. Thank you
mattblast
Bridgewater, NJ
FORWARD / OFF / REVERSE label for Rusnok milling machine. Sometimes only a simple label is needed for a restoration. Printed on 3M white with a scuff resistant polycarbonate lamination, then contour cut to size.
Before:
After:
poeseph311
@mattblast I was able to fix up the headband but the model number label is beyond repair. If it's too much trouble to change the number, I could just buy another copy of the one you already made if that works for you. Thanks in advance!
mattblast
Bridgewater, NJ
Send me a photo of the original and I’ll see if I can make an exact match.
mattblast
Bridgewater, NJ
here is my most recent label reproduction.
LeBlond Metal Lathe Threads per Inch and Feeds chart reproduction. Printed on clear and applied to aluminum with a scuff resistant lamination added. This took a couple hours of design time to get everything lined up perfectly and figure out what the damaged sections were supposed to be.
Before
After
poeseph311
Thanks @mattblast . Unfortunately the model number label is fubar. I can only barely read the stamped numbers on it. If you need a pic of it in order to reproduce, I could just take a copy of the 103.24500 that you made for someone else. Attached are pics of my mangled number plate. Also the craftsman logo if you are able to reproduce that too, it didn't clean up as well as I had hoped.
Thank you again!
Old Radar
San Antonio, TX
^^^ Judging from the back of the label, I read 102124530. Spacing would suggest there is at least one character in front of the first one. You might try holding a light at a low angle to see if anything else becomes visible in shadow.
