Cable rope crimping die
branimal
Can I buy a die to crimp 5/32 7x19 cable rope for this crimping tool? The crimping tool was used to install stainless steel cable for a stair railing system. The die is hexagonal and measures 10mm. It is replaceable, but the company is in China - tough to get a hold of anyone. I was wondering if I can buy a generic die to replace the existing one.
The model # is JT-150.
billconner
Thousand Islands NYS
May Pop
Lake in the hills Il.
Geelee Funny
Those are Greenlee knockoffs
Try taking just your dies to Harbor freight and match the up to their cheap hydraulic crimping set. Also the same sets are sold on E bay and Amazon. They all appear to be made in the same factory, different box. The die in yours looks very similar.
I think the whole hydraulic set was 30 bucks. It has 8-10 dies.
branimal
Here's a pic of my die. The HF dies are also pin style. As are a set I found on Amazon. My die differs in that it has a protrusion on each side. Anyone know if it will work?
billconner
...refundable I think.
Is the 7/32 wire rope with these swages a critical life safety application? I've spent a lot of time with wire rope (and chain and other ropes) in my career, and just wondering.
branimal
Ordered it. I plan on using the 5/32 wire rope attached to an electric hoist to lift cast iron steam radiators into a lye bath to strip the paint.
I did some smaller radiators (maybe 125lbs) with the long leg of a ratchet strap attached to a fabricated metal hook. (Two straps, two hooks). I have a bigger radiator (250lbs) to do soon. The hooks cannot fit anywhere on the radiator. The fins are too narrow. The wire rope is narrow enough to fit thru the slim fins of the radiator.
I figure 2-3 wire ropes should be adequate to handle the load.
billconner
I think you'll be fine. 2800# breaking strength on 5/32 GAC, 10:1 design factor. The swages are nearly 100% (I think clips are in the 80% range?) I'd guess winch is the weak link, but not a real risk. Seems load is never over heads, so no great hazard.
Apologies, but it's been 4+ years since I last designed a rigging system so a little rusty.
branimal
The die kit I ordered off of Amazon didn't fit my crimper. Still waiting for the Chinese customer support to get back to me. ;> I found a guy on FB selling an everbilt crimper cheap. Works well once I have a cheater bar on the handles.
thanks for the help guys.
tarbellb
Oregon
Couple smacks with a hammer and you'd be fine for this application
But I'm all for purchasing new (appropriate) tools
PCustoms
VT
Why crimp something that's not designed to be permanently used?
