Hi all-
I'm in the interior planning phase of building my woodshop. There is already shop thread on it, but the interior shop space is 20x36 with 10' sidewalls and a 15' vaulted ceiling.
I'm nearly done with the siding so the next step is to work on electric, then insulation and interior walls.
I will be putting a lot of standard quad boxes at 50" above the floor and a few on the ceiling so those are pretty easy to place.
A lot of my larger tools are 240v (planer, jointer, tablesaw, shaper, dust collector, large bandsaw) so those outlets I'd like to have placed pretty well for actual tool use. Most items will be on mobile bases so they can be adjusted as needed (pulled out away from the wall when in use for instance).
What do you think about this preliminary layout? I'm also not sure how to bring power to the tools on the center of the floor, should I do 240v ceiling drops or run chords on the floor? For lighting I will have two rows of LED lights running lengthwise on the ceiling, and I plan to use a few pendant fixtures for task lighting hung from the ceiling along the perimeter where work areas are (i.e. two high over the work benches, etc).
This is my first dedicated woodshop space so any feedback would be appreciated, thanks!
