Above 1200 Sq/FT Shorty's Shed
cbacres
SW Florida
Got the door off without issue and the new hinges on the A pillar.
Unfortunately the hinges have to go on the door first. I realized the fender had to come off to do alignment but hey, give it a try.
Last night, the front bumper cover is off and the fender is almost off. There’s a secret fastener somewhere and there’s no YT video on this fender. 🤔
Did ya paint the new hinges?
Good idea on the door lift!
shortykorte
Tallahassee, Fl
Good news. After this…..
Door and fender was installed. I guess with CAD, parts have tighter fit. Everything bolted together really well, just minor adjustments, no shims.
After reinstalling everything, only one bolt and two plastic push fasteners left over. I didn’t see any empty holes so I think I’m good. 🥴
shortykorte
Tallahassee, Fl
After getting the layer of ice off the windshield, it was time to put the miniature mule Kadee to work.
Borrowed a friend’s 3 point rake to clean up all the small branches, twigs and pine needles from my lumberjack work.
Sure beats hand raking. Another reason for clean up is it’s stump day!!!! I think this will work.
He got a late start but did get all 11 stumps up.
And two of nine trees pushed over.
And my lunch today. Yummmm
shortykorte
Tallahassee, Fl
Well, well well it’s 2023 and time to kick off this years North Florida Safety Sessions.
Come join in the fun. Our first class will be teach the teacher on proper cutting up trees procedure. Class is free. Bring your own chainsaw. Tasty beverages will be made available after 9am. 🍺
shortykorte
Tallahassee, Fl
Oh well no sign ups so more beverages for me.
I’m using a borrowed pair of clamp-on forks to move logs around. They work but going backwards they get caught up in the ground and slip off. As part of an auction I won awhile back, there were two sets of over the bucket forks. I decided to make my own quick change forks. First step, cut the vertical part down from 48” to 28”.
I know very little about setting up a torch so the popping and sparks around a plastic gas can and a LP tank made it a little nerve racking.
Ended up using the portable bandsaw to cut through the boogers and a new blade made cutting the second fork easy.
zmotorsports
Northern Utah
Shorty, the biggest issue I see when people try using oxy/acetylene cutting rigs is the gas pressures too high. It actually takes less than you think. Not sure where your is set at the regulator but for most light to medium cutting I only have my gas pressure around 3 PSI. Then the oxygen will be upwards of around 20~ish or so. For a fork blade that is quite thick you may be somewhere closer to 5 PSI but shouldn't be much higher. Then adjust the flame to get a nice crisp fine point with very little halo. I just helped a co-worker a few weeks ago learn to cut with a torch and he was doing well after a little fine tuning of the setup.
Not sure if that will help or not but you may want to give it a try. FYI, I have a nice ESAB Plasma cutter and I still feel that for thicker materials an oxy/acetylene gas setup is more efficient and just as easy to get clean cuts with. But again, I'm kinda old school.
shortykorte
Tallahassee, Fl
Thanks Mike. Watching videos, I have mine set at 7 and 40. This week saw one that said when using a #3 tip oxygen should be bumped up.
Adjusting the tip is where I have biggest issue.
“Then adjust the flame to get a nice crisp fine point with very little halo.”
Exactly what is the point? Is it the little blue points at the tip holes or the bigger tip that is created?
zmotorsports
Northern Utah
Sorry, the tip of the cone. When adjusting the cone it will be blurry, fuzzy or whatever you want to call it, but open the oxygen up until the tip of the cone comes in nice and crisp. Also make sure the oxygen at the lever is fully open. I then will usually hit the full-oxy lever a few times to ensure it comes back to crisp when released.
scooterbum46
South Central Michigan / ex Gulf Coast Florida
I'm not a welder (or weldor) (been years since I stayed in a Holiday Inn Express too), but the millwright that taught me the OA basics finally got me to understand that cutting is a process of burning the metal (chemical reaction with the O2), not melting through it. The best illustration is an oxygen lance, used for cutting huge blocks of steel.
cbacres
SW Florida
So….. did you do the slag in my open shoe dance?
shortykorte
Tallahassee, Fl
Spent some time logging
These sections at 17’10” I guesstimate around 1700#. A tad bit more than Katy can handle so, luckily I was able to use the loader bucket to roll them out of the way. May have to use the truck to drag the last couple out of the way. Still have a mess to work on.
Glad I was wearing my safety draws
The Craftsman mower stopped running so brought it to shop. Some rusty something blocking the fuel inlet and a dirty plug.
wish I had a spark plug cleaner. Got the mower back running so it’s good.
shortykorte
Tallahassee, Fl
Continuing on the quick connect forks, I used NOS steel to build the frame that connects to the loader.
Measure twice, mark the correct spot and weld the bracket offset about 3/4”. 🤦‍♂️
Had to cold chisel the end cap off. 😬
Instead of using what I have on hand, decided to do some CAD then buy wider flat bar.
