Above 1200 Sq/FT Shorty's Shed
shortykorte
Tallahassee, Fl
Been setting up the homestead.
When I put the septic system in, I had them install a lift pump for a RV. Unfortunately I wasn’t clear on location so they put it next to shop not road side of RV. Digging in clay isn’t fun.
And last, when in the country and want a hot tub…
The Camco portable on demand water heater is the bomb. The Mrs. and I tried it out tonight. Awesome under the stars.
Hopefully get started on the house in next 30 days.
shortykorte
Tallahassee, Fl
Just a bunch of miscellaneous things and still moving stuff out of the house.
When testing the lift pump before backfilling, oh ****.
Thankful the manufacturer replaced it.
I did some basic cleaning and paint stripping on the tubs exterior. I want to sand bast it but for now, primer and paint.
Looking at the stamping, the tub appears to be casted in 1903 or 1911. Company closed in 1929.
When a 30x50 shop, a 40’ container, a 12x20 portable carport and two self storage units aren’t enough, get another carport.
Three storage cabinets and two Vidmar cabinets that are still in house garage will be stored here along with parking for the tractor.
shortykorte
Tallahassee, Fl
And who said keeping junk doesn’t pay off. A scrap of plywood from the whse shop demo in 2011 became 3 shelves for a garden closet.
The jig saw and router cabinets don’t shelves so found these out back.
I think they came from the gas pump I scraped. After cutting to length and bending a matching flange on the cut end, a shelf…like it was made for cabinet.
I since this worked, I’ll use the other pieces to make more shelves.
shortykorte
Tallahassee, Fl
The two fence post and a tarp has to go. The breeze and wind gets strong at times so something more permanent.
I did the fence section and the wife did everything else. Definitely much nicer.
Wasn’t a great place to put a bar of soap so whipped this up out of aluminum fascia material.
It’s self supporting, no screws and the top is angled to keep rain off the shelf.
While digging the hole for the fence corner post,I found water 😟. Tracing where the water was leaking from, I found the leak being the shop supply line but up underneath the slab. Ugh. 😩
New plan included a shut off valve outside the building. Used a valve box and a piece of an AC duct to access it.
Came up the outside wall then inside. Did everything in PEX and even have a coil going up to run to other corner and the bathroom sink so that’s a positive for the leaking pipe project. The removable panels made it easy.
shortykorte
Tallahassee, Fl
Still trudging a long with various projects. Installed outdoor outlets for the RV lift pump and the septic pump. Which eliminates one of two extension cords.
Finished emptying the garage at old house so need (my wife) more space. This lead to working on walling off the loft.
And setting up the shelves I used at whse loft. Repurpose, reuse, recycle.
This freed up floor space and some items found the trash can.
shortykorte
Tallahassee, Fl
Ok which one of you guys left the freezer door opened?
To cold to do much but doing something. Oil pressure was showing 0 psi but luckily no lifter rattles. To R&R sensor, they say remove the intake? Remove the intake!!!
Thanks to Bob (bore scope) and YouTube (tips) I was able to replace. IMG_2421.jpeg
Lost count on the number of WTF and f@$#%.
Picked up a half price hand truck so moved the hot tub heater over to it.
Filled in the axle area with sscrap wood to hold bottles of bubble bath. IMG_2422.jpeg
The place I got the hand truck, had these portable ping pong tables.
Decided the base could be a nice saw horse.
shortykorte
Tallahassee, Fl
From shorts and Florida Safety Shoes to multiple jackets, long pants and
The last few weeks have been cold rain on Saturday, thaw out on Sunday. Yesterday we were blessed with this weird stuff.
Power went out at 3am. This morning
Decided to drive into town
And ended up taking this beautiful picture.
Now finish out the week with sunny but temps 20° below average. GW is real. 🤔
shortykorte
Tallahassee, Fl
With the nice weather, energized to get out and knock some projects off the list. First up, cutting up some of leftover Christine so I can haul it to the scrapyard.
Also spent an hour or two troubleshooting which septic tank item was popping the GFCI outlet. First checked that the outlets were ok. There’s three cords. I found The culprit. I think it’s the pump to the drain field. Installer said the pumps are know to trip GFCI outlets.
Next up was temporarily wire up a dryer outlet. The RV’s all in one washer-dryer, washes ok but drying takes forever. I think it’s made to only handle my Speedo. The new dryer works great.
Finding a spot for the new dryer (and store the washer) resulted in shop Tetris. This forced me to do some clean up 👍.
My old 15 yo cordless impact is on it last leg so Santa delivered some new tools. They’ve been laying on the bench, so I put up my drill holder.
I’ve got to find the matching holder so I have a place for the 18v.
Got on the tractor and move one stump and branches to the burn pile. Surprised at the number of 3-4” diameter branches the snow/ice brought down.
The most important task was this….
Now where is the TV?
Sore and pulled muscles I soaked in the outdoor tub, looking at the beautiful moon and stars. Relaxing.
And for your viewing pleasure, an early ad release of Shorty’s Florida Safety Shoe new Spring apparel.
PugetDude
Superstition Mountains, AZ
You need a pair of these,.
