DeWalt DW735X Planer
oldtimehockey
Whidbey Island, WA
Hi Guys and Gals on the Garage Journal
I bought a brand new 13 inch DeWalt DW735X planer with the infeed and outfeed wings and a set of brand new cutter blades. I know it has the built in blower to help push the wood chips out of the machine. I also have my planer hooked up to a very powerful Oneida dust collection system. After I run a board through the planer, taking very thin cuts, I am finding a series of small "depressions" or "indentations" scattered throughout the face of the board I just planed. Am I doing something wrong...??? Do other woodworkers out there get the same results...??? Any comments or recommendations/advice or tips and tricks that y'all are willing to share...??? Thank you so very much. Happy St. Patrick's Day to all. Slainte, Oldtimehockey
O
oldtimehockey
Whidbey Island, WA
What wood? Have you checked that the indeed and out feed tables are parallel with the planer bed?
Thank you for replying...Planing straight grain Douglas Fir trim stock for a window trim job. The infeed and outfeed wings seem to be correctly installed. I had heard some scuttlebutt that the combination of the DeWalt's integral chip blower may not work well along with a strong suction dust collection system running at the same time. It's almost as if some chips get trappedinside the machine, stick to the rollers and then the stuck chips compress the face of the boards in several tiny spots along the length of the planed side of the board. Does that make sense...???
cgrutt
I think I have same planer and used to run it with an Oneida-air collector don't recall having any issues with the dust collector. Is the tension bar (if yours has one) pushed in when running stock through it? I kept a piece of 1/2 plywood that I ran through bottom of machine across both infeed and outfeed wings to ensure everything was on same plane before. Clamped it to end of outfeed table to keep it in place. Also changing direction of boards may help if you're getting any tearout but doubt that would be problem with Doug Fir.
dscheidt
Do you have nicks in your blade? The dewalt blades ****, and I've had nicks in any set of mine after 2 boards, tops.
those sound exactly like the indents I get when not using my dust collector. I have the 733. Let me check w my buddy w a 735. Is the X important differences?
Can you add a wye to the DC inlet to bleed off some excess vacuum to maybe help the internal blower?
never enuf time
North of the Motorcity
It's the chips from previous pass denting board. Yes this happens to me also. Chips are more prevalent on small width boards.
Run wider boards first, clean or blow with compressed air to do best get rid of chips.
Sometimes dust collector is overwhelmed from a board and will leave chips/shavings. Its a learning/frustrating process
neophyte
Pennsylvannia
Douglas fir is full of pitch, especially new stuff from a home center that is not really that dry.
The pitch can and will get on the rollers pulling wood thru the planer, resulting in chip buildup.
Some shops won’t let pine or Douglas fir or similar woods be planed, because they fon’t want to deal with cleaning the pitch out of the planers and jointers.
Even decades old fir lumber will get pitch all over tools though.
decableguy2000
I would check the blades for damage, if I remember correctly, the blades are shrpened on 2 sides and can be flipped.
Damaged blades will give you consistent ridges down the board, not random ones. If you can offset the damaged spots, you can hide the ridges. Tthe 735 blades do have 2 sharpened edges, at least the replacements do now.
tarbellb
Oregon
super soft wood plus rollers plus chips = dents
you may want to try running compressed air or a blower directed at the offending area.
O
oldtimehockey
Whidbey Island, WA
Thank you so much for your time and your help.
O
oldtimehockey
Whidbey Island, WA
Wow...that explains a lot...Thank you so very much for teaching me that.
O
oldtimehockey
Whidbey Island, WA
That makes sense because my boards are not wide at all...I've ripped them down to less width than 1 x 6 stock. I hope my dust collector isn't overwhelmed...that would be more disappointing than this planer problem.
O
oldtimehockey
Whidbey Island, WA
Wow...thank you for your reply...I'll try both of those tips...thank you for your time and replting to my thread.
Aileron
outside
i bought a 735 end of december . haven't used it yet but from what i read about the 735 it worked better and was not supposed to have a dust collection hooked up to it.
tarbellb
Oregon
Did you try running without the dust collector, cleaning the rollers, compressed air, or harder wood?
O
oldtimehockey
Whidbey Island, WA
I didn't try any of that. Using the planer without the dust collection made zero sense. The planer is now resting comfortably at my local Rockler dealer. Thanks to all for your time.
tak1313
I've had 3 planers, including the Dewalt, and have had those with all planers, especially on softwood. As others have said, they are caused by chips getting pressed into the wood by the rollers. There's almost no way that I know of to COMPLETELY eliminate it ALL THE TIME.
I don't know what Oneida "system" you are using, but if it's based on a vacuum cleaner, it's doesn't pull enough CFM to eliminate all the chips while planing.
The closest I can get is by using my full size dust collector. I find the "assist" provided by Dewalt's internal vacuum plus the dust collector helps in just about eliminating the problem.
tarbellb
Oregon
Running without the dust collector is more of a test to see if it made it worse, then you can start to remedy from there.
Either way youve made the decision to step up to the big boy planers, hope that solves your issue, keep us posted!
neophyte
Pennsylvannia
My experience with a few “industrial” planers says that the chip issue might still exist,
Although maybe the chips will stick a bit less yo steel drive rollers or the industrial units will allow slightly better chip collection.
I still routinely had to stray compressed air across planer beds as lumber was being pulled thru and planed, to clear chips, even on industrial machines with industrial level dust collection.
metaldad
nw indiana
well, this is an interesting topic.
i also recently acquired a dewalt 73somethingornother
ran a coupla oak boards just for operation check.
seemed to work ok. wont know for sure until it gets warm out
