Post your acid stained floor!
El_Diablo
Wooster, Ohio
I've looked through many pages in this section without many clearly defined posts of what I'm looking at. I figure this gives everyone a chance to post what manufacture, process, products, color and finish they used so that those of us trying to decide can have a reference.
So go ahead and post away :thumbup:
CDriver
EL Diablo, hope you don't mind me asking some questions in your thread but maybe you can answer... Can a clear coat be added over an acid stained floor? Will it be just as protective as epoxy base/clear system? I love the look of metallic epoxy but the cost is above what I'm willing to spend. Seems like an acid stained / clear coat would be a great alternative solution.
E
El_Diablo
Wooster, Ohio
Clear is the only way the stain will actually "pop" and not just look like dirty concrete. There are a number of clears available from what I've seen. It's all in finding one that is durable enough for the use that you intend.
Armorpoxy
Here are some photos of a recent project we supplied. Two colors of stain, one coat of SPGX.
This floor was in VERY bad condition originally. It was grinded to a #120 and the customer wanted this 'distressed' look so hence the staining. There were a lot of prior repairs, patch, etc so the staining did a good job of hiding and visually distracting the problems in the floor.
This was for the office/waiting room of a commercial auto service center.
zporta
Any negatives to acid staining a garage floor?
Getting ready to build a house and spring and running a lot of ideas through my head. Plan on staining the basement floor that will have radiant heat. The garage will also have radiant heat but not sure about the concrete finish. Might possibly just so with a simple satin sealer
ChargedUp!
Twin Cities, MN
I've had a local flooring installer tell me they wouldn't warranty a stain like this in the garage. This leads me to believe it won't hold up. Will a stain last in a working garage?
Armorpoxy
A stain and sealer system would not be as thick as a 100% solids epoxy system so long term life would be less. Of course if you maintain and add a coat to the sealer every 5-7 years or as applicable the floor should last indefinitely. Nothing lasts forever and all floors at some point may require some TLC.
Brad J.
Our basement floor was stained with A waterbased stain that looks like acid based products. It was sanded with a floor sander, stained with a pump sprayer, clear coated with a quality clear (no waterbase) cement sealer, and then regular floor wax applied.
Friend that applied the stain didn't want to mess with neutralizing the acid stain in a finished room with baseboards and stuff. That is why we went with the waterborn stain.
It's brown and looks like the others on here. Can't tell the difference.
As I look back I wish we would have just used a clear like Armor Poxy sells instead of the floor wax. It's been three years and needs another coat of wax but the wax scuffs fairly easy. Wouldn't look that great if it was high traffic but it holds up good for us.
Oil dripping from the cars eats the wax a little where the tires sit over the winter leaves bad black marks.
If I wanted to strip the wax and go with a clear system how would you do it?
LegacyIndustrial
deerfield, IL
He is not offering a high performance sealing product like our Nohr-S Polyurea.
2-3 coats over it will have no issue protecting against the ills of a garage.
Armorpoxy
A single coat of our SPGX would do the trick and give many, many years of outstanding service.
hercules633
I see this is an older thread, but would also like to see some stained or dyed concrete floors. I love the epoxy look and have even had the great pleasure of assisting on 2 installs. I think staining or dying will work better for me. I have in floor heating, not up and working yet.
Let us know what products and colors you used please
LegacyIndustrial
deerfield, IL
Do yourself a favor, obtain a sample kit and do some tests in a corner of your garage or where a toolbox will go later on.
Every floor reacts with these stains differently. Our sample kit contains some benign sealer as well, helps to get the full effect.
Good luck
hercules633
I would like to get some ideas in what stain color to go ahead with. I like bright.
pablo94sc
Memphis
I've always been curious about this. About how much does something like this cost per sqft?
Birdman89
Ontario
Are you able/willing to ship to Canada? If not can you recommend any Canadian vendors for stained concrete or epoxy systems?
Armorpoxy
Hi,
We ship to Canada daily. No duty, but additional shipping fees apply, and customer is responsible for any GST/HST and clearance fees, if any that get charged by our carrier, normally FedEx Ground.
Thank you.
Toolfool
Tallahassee, FL
Two Pump Chump
N CA
I think your diet ***** !!! The videos all show cheap hand held plastic pump 1 or 2 gallon units . . ..
RPH
Michigan Thumb
4 color acid stain. Then ghostshield densifier and then 8505. Floor is not shiny but it’s not gray.
CamMark
Palmetto State
I've been waiting to add mine here. Just finished up yesterday.
This is a single color, Taupe from Eagle, diluted 1:1 and topped with Ghoastshield 4500 and 8510.
The slab was power troweled smooth, but no other finishing. Prep was a thorough sweep, wash and scrub with the etch & clean then rinse and squeegee dry. I did mist the floor with water before laying down the stain as suggested on the label. I left it to work for 6 hours almost exactly before hitting it with neutralizer and rinsing. There were probably 3 full cycles of neutralizer/scrub/rinse/squeegee before we called it good for sealing.
Toolfool
Tallahassee, FL
Thanks for reminding me, I finished the floor in the garage area of my building.
First pic is floor neutralized and washed, lines masked, stained and sealed.
Second pic is after three coats of Dayton Superior TufSeal J35. Did two more coats after this.
CowboyNeil
For being Taupe I am surprised by how almost purple colored it is. Wow. Looks good though. I have been thinking of going this way myself.
