Barrel Pump Sticking
Jmellc
Durham, NC
Barrel pump at work is sticking a lot. If it sits awhile, it gets really hard to crank. Once I break it loose, it works OK. Do I need to open it up and lube it? It doesn’t have a fitting for a grease gun.
Thanks for any help.
What are you pumping? Is there something that could be fouling / crystalizing / gluing the innards together?
J
Jmellc
Durham, NC
Well that might be your problem. That pump may not be compatible with your soap, especially if its water based.
I’ll have to read the label. I guess if it is water based, not much we can do. Should get a more suitable pump.
