So the next couple of posts will be picture heavy again.
I dropped the tires/wheels off Saturday morning to have them mounted and balanced then came back home to commence the paint correction.
So far I'm about 5 hours into the paint correction and I have the front clip completed. It's slow going but well worth it when you see the results.
I know a few had asked for a video so I am recording how I perform a paint correction so a video will be posted to my YouTube channel once the car is complete. I must state that I am old school when it comes to cutting and buffing paint. I use older products and not the fancy smancy one-step polishing techniques that seem to be so popular by much of the DIY crowd. I have found that the single step process don't remove all of the scratches as they use a less aggressive compound along with the DA type polishers. I've seen some nice work but if you look closely enough you can still see scratches and that just seems like a lot of work for less than perfect results.
The process I use consists of 3M polishing compounds and a combination of wool and foam polishing pads along with a standard circular polisher rather than a DA style. I first use a clay bar with lubricant/detailer to remove any tree sap or residue before going to the first step of compound which is rather course and a white wool pad.
I also go one step further and mask off trim items and other accessories to avoid any compound getting into them, especially the textured black trim as anyone who has gotten compound in those knows how much fun it is to remove later.
Tools and supplies used.
Clay bar on the hood, roof, trunk lid, top of front fenders and top of rear quarters. I also noted a few spots with yellow masking tape as I went around the car with the Final Inspection detailer prior to breaking out the clay bar. I hit those few spots as well before wiping down and prepping for compounding.
This part isn't necessary but sure pays off huge dividends when it comes to final detailing. I also waffled on removing the small Camaro badging on the front fenders as I generally debadge all of my vehicles. However, seeing as how I am going for the clean, stock look on this car to someday be able to hand down, I went ahead and left the badges on the car, just masked them off to prevent compound from getting packed in them. Also kept the hood popped slightly while polishing the hood. If you note in later pictures you'll notice the hood being closed to avoid catching the edges.
It's hard to see in the pictures but there are an awful lot of small micro-scratches on the hood, tops of fenders and front bumper cover above the headlights. It appears as though it was driven through a lot of car washes but can't be certain as to the cause of the scratches.
First step. Course compound and white wool pad on the hood. You can see the heavy swirl marks from the course compound as I had to get rather aggressive to remove the scratches.
The driver's side has now had the second step completed and you can already see the difference from the first picture. Step two consists of 3M's Finesse-It compound and a yellow wool pad which is a step finer from step #1. The heavy swirl marks are disappearing and the depth of the shine is really starting to come on strong. I have one rock chip on the front quadrant of the driver's side hood that is quite deep and through the clear, everything else is coming out perfectly.
Another shot of step # 2 completed, trying to catch the light from the window and you can see the clarity in the paint.
The front two corners of the bumper cover had a lot of scratches but after a heavy polishing using the course compound and white wool pad they are a thing of the past. Also had a few around the mail slot which quickly disappeared. The lip along the grille between the headlights was actually in decent shape but after a couple passes with the compound and polisher it looked even better.
More pictures to follow.....
