What should I do about concrete walls?
wolfy0434
So we just moved into a new build. Ignore all the junk right now. 3 stall garage. I work on bikes on the side so want to epoxy the floor. Have a good company coming in to do that next month. Any ideas on what I can do for the concrete walls? Anyone just paint over them. Down the road I may insulate the garage but not gonna do that yet. So any ideas would be appreciated. Thanks!
Shiftless
East Bay SFO
Yeah... Paint and if you don’t need cabinet or shelf space, hang some motorcycle posters and it will be fine.
billconner
Thousand Islands NYS
Anything you gotta do for prep before? Or just paint it and your good?
Agree with Mtl-Marc. I thought about suggesting pressure wash, but a bucket of sudsy tsp water and a scrub brush, followed by a hose rinse is probably fine.
But a masonry paint that I believe does not seal - let's vapor pass through - is what I'd look for - especially if those concrete walls were filled behind.
428PI
Peabody, KS
Masonry paint. Good and cheap. That's what we did on our basement walls. Holding up fine for 20 plus years now.
dougf
Missouri
For the low walls I would paint them, or even leave them. For the high walls I would tapcon 3/4 plywood to them so you can affix shelving there, or hang signs, etc...
Stelzer
Portland, OR
Clean it off, then roll a coat or 2 of Gardz over it. It'll seal it up, keeping it washable, and prevent it from crumbling or taking on stains/fumes associated with garages. Gardz was originally formulated as a concrete sealer, (modeled after the OG Draw-tite).
NUTTSGT
Northern Central Ohio
I'm curious as to the layout and why on the full height walls, weren't all covered like the rest.
Those bare concrete exterior walls will be sucking all the heat out of the garage in the winter.
BombShelter
State of Hockey
I like Thoroseal a lot better than Dryloc. Dryloc tends to flake off easier after a few years. Both come in white but a color can be added and they go on real thick to hide imperfections.
65ranchero
Danville, VT left NJ forever
What I did for the stem walls (2ft high) is get some InSoFast insolation panels (2x4) cut them so you now has 2x2 panels
use the glue specified which I think was PL 400 ( Premium?) let it set up and then I attached white smooth FRP panels to the ribs with counter sunk screws and washers.
Goes up fast.
