Sawmill
R
RivennHewn
PNW
The interior humidity (top) has been running 15-30% lower than the exterior humidity.
Once I loaded it, the interior has jumped up considerably.
This load has been stacked outside for a few months under cover, but it has a long way to go.
Good thing the weather is headed in the right direction.
PCustoms
VT
Can you setup a remote/probe for the wood and put that next to this display?
Better yet, to WiFi enabled and link to this thread !
R
RivennHewn
PNW
The set up is low-buck and elementary.
As i research and pay the bigger bucks, I’ll go with a Bluetooth /data recording app so I can track/print out the progress. I also intend to purchase the Wagner Orion moisture meter.
It also is BT, and you can print out a status report for customers.
PCustoms
VT
I was serious about having a permanent probe for the wood, but joking about linking it here. That setup looks pretty slick.
R
RivennHewn
PNW
Need to clear the logjam out of my driveway.
Started with an ugly old Cedar.
R
RivennHewn
PNW
You must have been board today huh?
No time to be “board”, I have a to-do list from the wife!
One item was clear the driveway.
Actually, we have the pavement getting scrubbed and recoated. Time to clear the whole dang thang
R
RivennHewn
PNW
Another “Special Projects” task ✅
Mounts for the peavey on the ol’ Dually.
Wasn’t quite sure if this should go here, or in:
R
RivennHewn
PNW
Update on my little nurse log project.
As of last week, there was still some green on the leaves. Now they are all black😕
But, it does have two new buds!
Hoping for the best, but expecting the need to order a few more seedlings.
In hindsight, planting them in January probably wasn’t the best idea.
Toolfool
Tallahassee, FL
My property on Whidbey had been logged and was a pecker-pole farm when we bought it. I planted about 250 DNR fir seedlings and 100 cedar seedlings during the first January we owned it. I didn't find any dead ones after the first year. Keep hope alive !
R
RivennHewn
PNW
Picked this up from a neighbor. Actually, he gifted it to me.
It’s designed to pull floating logs up a boat ramp. Sound familiar?
Sounded to good to pass up.
I’m thinking I’ll be making some modifications to the design, to fit my needs.
It is currently registered, but has no lights.
Harbor Freight for the win!
dcg9381
Austin, TX
Someone in the family owns a "large" sawmill.
This may be a dumb question but how do you get the log off when you get home?
They use a crane truck, then lower individual logs to a very large skid steer.
When we've hired "portable" mills, we've moved logs with a Kubota tractor and forklift forks.
Here's the mill.
For mere mortal woodworkers, they sell slices of these logs for others to finish... Which would make a lot more financial sense to most of us without this type of equipment (myself included).
https://www.txurbansawmill.com
This is a finished piece that I did with help from this sawmill. With "help" I mean, I did the dimensional drawings for the space/fixtures, and got my *** out to their shop and followed directions. I envy you guys with "wood skills" - definitely not my cup of tea. The "bowl" and faucet are things that are available over the internet.
R
RivennHewn
PNW
Here's the mill.
Thanks for sharing!
Sink looks 👍
R
RivennHewn
PNW
Spent an hour cutting a sled to flatten a Madrone slab for a client.
Shim and secure the warped slab to a 1-1/8” panel, run one side til it’s flat, then flip it over and run til it’s flat as a board.
Shim and secure the warped slab to….
Madrone warps? Who would have known?
Years ago we bought a slabbed log of madrone to attempt to dry it ourselves. He warned us. One small log, weighed down with cinder blocks, should work fine, right? Within two months of air drying, it had tossed off all the cinder blocks . Still trying to find projects for small bits of madrone, like saw handles. Beautiful stuff, but what a pain.
R
RivennHewn
PNW
My last “slab” of Madrone turned into 2X lathe stock.
Turned a nice set of chisel handles out of them.
Madrone excels at turned chisel handles😜
