Bench grinder - adding a threaded tapered spindle adapter
fishwatcher
I recently got a 6” bench grinder. It’s a very typical MIC grinder, lots of products look like this.
It has a 1/2” arbor, with threaded ends. I bought a 1/2” threaded taper spindle adapter, to easily swap buffs.
It installs via a smooth bore and a set screw. Only the further out set screw fits and it’s screws right into the edge of the smooth and threaded section of the arbor.
Are there tapered spindle adapters where the bores are threaded and there is a flat section to use a wrench on? Seems like it would be a higher quality join between the arbor and the spindle adapter. If this exists.. please share any links. The one I got was $15 a pair (Left and right) from Amazon.
That little set screw doesn’t give me a lot of confidence.
PoorUB
Fargo, ND
Is the bore deep enough to cut off the end of the adapter closer to the hole so both screws can get a bite?
I never used one of those adapters on a bench grinder. I used an old 3600 RPM motor I had.
F
fishwatcher
That’s a possibility worth checking out. However.. that second grub screw would then be biting into the arbor thread.
I’m going to see how this works for now. Maybe just a dab of loc-tite will help with the single grub screw.
Zeus36
Ventura, California
Drill and tap for a second set screw at 90 degrees to the factory screw. Same distance from the end of the adapter. If your still concerned, add three setscrews in addition to the factory one - giving you four points of contact at 12, 3, 6 and 9 clock positions. That will give you a balanced weight load. Doubt that would be much of an effect at 3450 RPM ... if it were me, I'd just do a second setscrew at 90 degrees.
RoninB4
Under My House
-It's not just the ONE set screw that makes me question this. A buffing wheel at that extended distance and the amount of force needed to use the buffing wheel creates considerable deflection loading. That moment, combined with ONE puny 1/4-20 set screw holding it all in place, at speed, is highly cringe worthy. If/when that set screw backs off, even a little, the momentum can/will whip the whole assembly around as it walks off the shaft. It can either bend the shaft or launch the assembly into the operator or anything in the flight path. The fitment of shaft to collar can also contribute rotational problems (ellipse). The advice of a "second set screw" isn't really good advice either, a set screw shouldn't be the primary constraining factor on a rotating assembly like this. It may appear to work fine but how many sessions will it last until it gives a false sense of security? Don't use this unless it's altered to be a safe design (it currently isn't). Could this set up work safely? Yes it might but if you don't understand what needs to be done I'd recommend not using/attempting this.
gregs
I would try to shorten it so that as much of the grinder shaft fit inside to provide support.
F
fishwatcher
@RoninB4 et al, thank you! I will heed these warnings.
So does anybody have a lead on a product like this with a threaded (not smooth) bore? It seems like there’s a market for them, currently addressed with a handful of similarly built grub-screw options like the one I got.
Zeke
I paid $60 for a MIC buffer with extended arbor housings. It gets hot after a few minutes use but for clearance to the wheel you can't beat it. I use a wire wheel on it too. Has a weird mm size close to 7/8th" so that makes buying wheels tough. Cloth are fine.
F
fishwatcher
F
fishwatcher
Thanks @mic214. What is a MIC buffer? Link? Nevermind.. figured this out 🙃.
Ideally I want to get multiple uses out of my bench grinder that are easy to make change without fuss. The room I have for additional tools is very limited.
alfadan
Augusta, ks
I suppose at a minimum, file an angled spot on the shaft, in that when you tighten the setscrew (with loctite), it pulls the adaptor tighter on the shaft. Blue the shaft with a sharpie and use the set screw to mark it and file carefully with trial fits.
F
fishwatcher
Like this a lot! Thx
F
fishwatcher
I think this might be the solution!
It says “threaded tapered”, has a hexagonal shaft (not round), and other products on their site actually mention set screws (this one does not). It also mentions 20 internal threads. l sent email into Tar Heel parts to confirm!
jayemm
up high down low
Aren't the threads on a 1/2" bench grinder shaft a 1/2-12 thread instead of 1/2-20 as mentioned above?
F
fishwatcher
@jayemm I think you’re right, it’s not 20 threads per inch.
I see 9 threads in about 5/8”. So I guess that’ll end up being 12 in one inch. Shoot. IMG_4244.jpeg
gregs
I'm betting that if Tarheel sells a slip on/set screw adapter that it must work ok and not fly off and kill people. I think if you follow some of the suggestions above all will be well. If you plan on leaving it on permanently you could add sleeve retainer or JB Weld to the shaft for an additional layer of safety.
F
fishwatcher
"sleeve retainer". Another new thing I've learned from GJ today, Thx @gregs!
