fishwatcher
- Joined
- Jan 26, 2023
- Messages
- 766
I recently got a 6” bench grinder. It’s a very typical MIC grinder, lots of products look like this.
It has a 1/2” arbor, with threaded ends. I bought a 1/2” threaded taper spindle adapter, to easily swap buffs.
It installs via a smooth bore and a set screw. Only the further out set screw fits and it’s screws right into the edge of the smooth and threaded section of the arbor.
Are there tapered spindle adapters where the bores are threaded and there is a flat section to use a wrench on? Seems like it would be a higher quality join between the arbor and the spindle adapter. If this exists.. please share any links. The one I got was $15 a pair (Left and right) from Amazon.
That little set screw doesn’t give me a lot of confidence.
Thanks!
Thanks!
