I like my chrome sockets, so I bought a set of 1/4" impacts to beat on. I use them a lot, breaking down old crusty motorcycles and other tasks.
I do like @Dave455 's set up.
Seriously just replace a chrome socket if you break it.Heh, I just remembered that if I do get 1/4" impact sockets then sooner or later I'll need to use extensions, and I don't have any 1/4" impact extensions. I guess I could always use my 3/8" impact extensions with an adapter, but that's pretty Rube Goldberg. The rabbit hole gets deeper and deeper...
If anyone has any stories and photos of 1/4" drive chrome sockets going flying in pieces from the torque of an impact driver, let's hear them.I'm not worried about breaking a socket so much as breaking it into me or someone else nearby if it shatters.
I think someone above talked about this, no? Also, depends on the driver. Mine is rated up to 108ft-lb which is probably conservative given that it's an M12 Gen 2. That's a crapload of impact torque. Of course you're rarely if ever going to approach that with an 8-12mm fastener as you'd likely snap the head before the socket shattered, but it's theoretically possible.If anyone has any stories and photos of 1/4" drive chrome sockets going flying in pieces from the torque of an impact driver, let's hear them.
Yeah I just don't see it. Theoretically aside, if it never happens it's not an issue.I think someone above talked about this, no? Also, depends on the driver. Mine is rated up to 108ft-lb which is probably conservative given that it's an M12 Gen 2. That's a crapload of impact torque. Of course you're rarely if ever going to approach that with an 8-12mm fastener as you'd likely snap the head before the socket shattered, but it's theoretically possible.
Exact same use case for me. Been using the Makita set for a few years now on an M18 Fuel impact driver, been perfect. Was ~$8 when I picked it up, hard to beat thatI like my chrome sockets, so I bought a set of 1/4" impacts to beat on. I use them a lot, breaking down old crusty motorcycles and other tasks.
I take it 1/2 drive was the drive size of the day?I f you are comfortable with what you are using, why not stay with it?
hen I started pulling wrenches, 1n the early'50s, the men I was around had very low regard for 3/8 drive stuff. i was a kid and was not aware of ignorant I was.
A lot depends on what you are working on.
I have the big set from Grey. It works good, but I rarely use it. It uses surface drive that makes the sockets seem loose on the bolts which may bother some people.
9772 | 1/4" Drive Standard and Deep Length Surface Drive Impact Socket Set
The 9772 is a 1/4 inch drive standard and deep length surface drive impact socket set from Grey Pneaumatic.www.gpsocket.com
I just ordered the Makita set. It's gone up to $14 but I had a $5 credit on Amazon so it was really $9. I also ordered a 14mm 1/4" impact for the hell of it. Just over $3 so I figured it wouldn't hurt. We'll see how often I used these but at these prices I can't really go wrong.I've got the smaller Grey Pneaumatic Set and both Makita SAE/Metric Sets (HD for $9.99 ea. on sale) and have been using them non-stop the last few weeks of warm weather. My cordless Makita Impact Driver works great but sometimes I need a breaker bar to start.
I still have to use chrome once in a while for tight fits, I've never shattered one with the Makita but have have stripped a few.
But isn't this an argument against the need for 1/4" impact sockets since the torque values are coming down due to all the plastic? Based on my own relatively limited experience (and at this point I've done nearly everything on a typical car other than take apart and rebuild the engine internals and the electronics), I think that use cases for 1/4" impact sockets are 8-12mm water pump, pulley, metal cover, oil/trans pan, manifold and heat shield fasteners, not plastic valve and timing belt covers, underbody shields and fuel pump access covers. I'm inclined to side with those who say that they're rarely if ever necessary, but got a cheap set just to be on the safe side.I've been bugging Chris Pettit of Astro about 1/4" drive impact sockets and my reason for this is a come to Jesus moment I had working on my best friend's Powerstroke 6.0 diesel engine. Once this engine was back in the truck space was so tight that for the majority of the accessories: like the turbo charger replacement, FICM and oil coolers that the only drive size that would fit into the tight spaces provided was 1/4". We torqued every single bolt we could on this build and at least 70% of the fasteners torqued were torqued with a 1/4" drive torque wrench. Also, with the European cars being made mostly out of plastic (that's you BMW) the need for high torque is getting less and less along with the space.
I recently had to drop the gas tank on my mom's Camry to patch a small hole just above the seam and my M12 impact driver was powerful enough to remove all the fasteners involved, including several exhaust hanger bolts to drop the rear tailpipe. I used a 3/8" impact adapter and 3/8" sockets, which makes me wonder why I even need to bother with 1/4" sockets since my 3/8" set goes down to 7mm, but at this price I figure why not.I've got the smaller Grey Pneaumatic Set and both Makita SAE/Metric Sets (HD for $9.99 ea. on sale) and have been using them non-stop the last few weeks of warm weather. My cordless Makita Impact Driver works great but sometimes I need a breaker bar to start.
