Mainiac Mat
Maine
Got out early today to wash my avalanche. Damn black paint earns up fast on the sun.
Friday night I was taking apart a carburetor in the garage and this guy flew in. I heard it coming lol. Biggest damn moth I ever saw. About a 6" wingspan. Apparently it's a lunar moth.
Pretty sure it's called a Luna moth.
rayra
Escaped from Los Angeles
cut down some cedar fence planks to make smaller planks for making wood doors for my outdoor grill counter. Got the basic panels glued, nailed and clamped. Tomorrow I'll trim them down to fit in the arched openings and figure out the hinging.
The doors will get stained with the same Dark Walnut / Danish Oil finish as the pergola beams.
BlakeTheCarGuy
Roanoke Virginia
Not busy today but also not slow. Steady is probably the right word. Done a couple things. They mainly had me going around fixing stuff that we failed our OSHA inspection for. Had to install guards on our bench grinder, prep the floor for painting a couple lines at different places, put a cap on the torch tank on and off valve, went around and gave every tech including myself a designated rag bin with a closed lid. The express guys were pretty busy and we didn’t have a whole lot so I told them I’d do it. We also all had to shift our toolboxes roughly 6 inches to the right because they have to be 6 feet from the electrical boxes. One of the express guys gave me an attitude about it and informed me that he was telling the boss that I wouldn’t consolidate to one toolbox like he (the tech) had requested since I had too many tools for his standards. I said you go ahead and tell him he is going to be ok with me being like everybody else and having two. He came over there and said I was fine and I’m the tool king of the shop anyway that provides tools to everyone so I didn’t have anything to worry about. I’ve never seen someone so upset over a toolbox his face was red and he was balling up his fist as he talked to me about it. Boss told him to go home for the rest of the day and come back when he could act mature.
Aside from that ruckus I done a couple 30k services on RAV4 which include a transfer case service along with oil change and rotate and air filters. And spent a lot of time on the Matco truck too haha. The company provided Chick Fil A lunch for us and when the company provides lunch we get to stay on the clock since we have to travel across the street to our other building to get it. I’m not complaining about getting paid to eat free food haha. I got to take home a gallon of lemonade that was left over.
npp
Had to find a youtube video. If I had to replace rotor I would have needed to make a trip to the parts store for a 14mm 12pt torx type socket to remove the caliper holder. There is also a tool for pushing the piston back into the caliper but I made do with knipex pliers and a short pry bar. Never mind the silly plastic caps over the lug bolts, yes bolts, not nuts. She had all the stock jack equipment including the key for locking lug nut. I've had to replace the pcv assembly too. https://www.myvwpart.com/p/Volkswagen__Jetta/Engine-Crankcase-Vent-Valve/67801091/06K103495AP.html?partner=BingShopping&kwd=&matchtype=e&device=c&network=o&userLocation=&msqs=2016 vw jetta pcv valve&bingCampaignID=367648708&bingAdGroupID=1218259323644410&bingAdID=76141316174487&bingExtensionID=
The socket is called a triple square and there is a special tool in the jack kit to remove the plastic caps, it is U shaped.
safetymachine
Vandalia, MO
Got the K-Whopper and hopper trailer inside and started on the wheels. The job is only a wash and interior detail. But I can’t let ‘er go back to the customer with tarnished Alcoas. So, started polishing. Washed 9 yards of gravel road dust out from under ‘er. Sharp rig, will finish the cleanup this weekend.
Old Man Roger
Palm Coast Florida
Those wheels had to take a good amount of time to polish, I hope the customer gives you a big tip.
safetymachine
Vandalia, MO
Yep me too! The Mothers Power Ball 2 and polishing compound does a great job. But they also take elbow grease. Maybe an hour for each wheel? Going to do the trailer Alcoas tonight. But of course, we’re going to get rain. So we’ll leave the rig inside and work on it. Then I’ll get to BILL IT lol!
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
@Metallitubby's Porsche wheel and valve cover are demurely finished -- in retina-searing pink! -- so they got packed up for shipping.
Finished bodywork on a 55 year old oil pan and got it outgassed last night for a few hours. Hoping to get it powdered before the next onslaught from Mother Nature this morning ... but ya'll aren't helping one bit by being more entertaining. Either that or one of you electrified my chair into an *** magnet. :ROFLMAO:
Happy Friday!!!
Chance
New England
Worked on the gear linkage on my caravelle.
2 year old relay lever on the side of the gearbox already worn out. Spline teeth have got slight wear giving about 1/4" movement of the linkage before the selector shaft moves. :rolleyes:
Luckily the selector shaft on the box is still OK.
Do you think they heat treat the linkage to a lower hardness number to sacrifice itself instead of wearing the selector? Which would be very cool enginering. Or is it just the luck of the draw?
Zebedeewesty
Wales, UK
Not sure. The selector shaft is chrome plated i think and probably hardened in some way and is the original factory part. The relay lever is just an aftermarket piece so probably not to the same quality. I'd still expect more than 2 years use out of it though.
Chance
New England
Maybe some HP grease will help reduce the wear the next relay lever.
CudaChick1968
Member Emeritus
What does it mean to do bodywork on an oil pan? Does that just mean a car was originally looking as dirty and beat up as an oil pan? Or does it mean to refinish the outside of an oil pan, like powder-coat it?
I'm a professional metal finisher and get projects from all over the world.
With very few exceptions, every part to cross my bench gets worked up to be as close to perfect as I can before any powder starts flying. This one just had a few dents, and some minor pitting my customer isn't worried about since it's going on a daily driver.
You might enjoy this thread.
Swanny1953
Lucas, TX
Getting ready for a car show tomorrow. Changed oil and detailed the ‘65 GTO, including under the hood using 303 Protectant - think it looks pretty good.
Interior hadn’t been detailed since I got it in July, so went over all the vinyl with Griot’s interior cleaner wipes and did a thorough vacuuming.
Did the same under hood detailing on the ‘51 Woodie wagon.
This one’s leather interior also needed a good detailing. Used Griots leather care wipes. Kinda forgot how much I like this interior -
This car has a C4 LT4 for power with a T56 6-speed. The speedo didn’t work when I got the car (duh, manual speedo, VSS output from ******!). I had a Cable-X unit from my ‘60 Corvette when I switched over to Dakota Digital in that car. I initially installed the Cable-X about a year ago, but, alas, it didn’t work. While doing an oil change this week, I decided to change the wire I was using for the Cable-X input. I obviously chose the wrong wire the first time as the speedo “worked” when I drove the car after the oil change. Unfortunately, the speedo was off by a factor of 2+x too high. Reviewing the Cable-X instructions, looks like I didn’t use the proper “pulse per revolution” number in my initial programming. I pulled the unit out and reprogrammed the dip switches for a setting I hope will be close. We’ll see tomorrow as thunderstorms this afternoon prevent any road tests.
Chance
New England
Thank you. Its a lot of fun learning about the folks on here.
rktinc
Midwest/USA
Need a color opinion as I am nearing the decision point. I have always finished my garages in bright ceiling white. I love the look. In doing this restoration and building my dream shop. I discovered the original color of an interior room during the demo phase. We have gone back and forth on using it.
Still deciding if the beadboard should be the same semi-gloss "creamy" as the woodwork or if I should paint it a classic green that I found during demolition of this space. The flooring is a very worn and stained red concrete for the most part and I am concerned the green might be a bit too much for the space.
Opinions welcomed...
Possible color choice??? Using Sherwin Williams "color tool" to add the green.
Thoughts?
C2AE4A67-0389-40B9-BDAA-8C6590CAF4ED_4_5005_c.jpegA40AFF4E-5778-4910-A316-D3F94E91ABED_4_5005_c.jpeg
The dark spot is my large black tool chest that will be parked there.
kaymccampbell
Upstate New York
Thoughts?
I vote for something lighter. That green is cool and old-timey, but will **** the light out of the room.
PassnThru
Bowling Green KY
Do what makes you happy. If you actually use your garage then in a few years the wall color will barely be visible due to all the cabinets and other storage. All the 'stuff' is going to determine the light levels - not the color of the walls.
rktinc
Midwest/USA
That is exactly right. I have lots of item to load into the shop area once it is painted included a row of 16 ACE hardware fastener drawers I bought from a closing store over 10 years ago. Unfortunately they are full of used fasteners instead of the new stock:). Lots of black tool boxes / chests a drill press and other items that will cover quite a bit. That was actually a reason to use the green but I am still heading toward the monotone look as it will be much easier to apply and not require trimming.
Chance
New England
I like the cream color on the trim. It has an old-timey feel without soaking up all the light. You could choose a slightly lighter shade to make the trim stand out more from the contrast.
