Wall + Tool Cabinet buffer
havinnoj
Hi guys - 60" roll cab sitting with its "back to wall" - but need to space it 2.5-3" from the wall itself. What can I fill this gap with? Obvious answer is a wood ledger, but wondering if anyone has other ideas to consider. TIA
Renegade1LI
long island ny
Get some strips of aluminum diamond plate & frame out the back of the box. If you don't want to put screws into the box epoxy some corner blocks to attach the diamond plate to.
rancherbill
Foothills County, Alberta, Canada
Make a new top that 3" larger.
I have been meaning to get around to making one. A sheet of 3/4 plywood and a sheet of galvanized steel..I know a furnace guy that I could get the sheet meatal from and just contact cement them together.
Walkers
Cave Creek Az
Get a piece of 3" channel iron, weld on something to allow it to hook on the back of the toolbox with the U facing up, like how the side cabinets hang. Then you can use it for holding spray cans all in a neat row.
HogDude
Nebraska
I kind of like this approach. Attached to the wall with added function.
