RaisedByWolves
EDIT: You can download the prints for this vise here.
onedrive.live.com
You’re probably thinking…He did a what?
It’s a type of low profile drill press vise to keep you from losing a finger when drilling small or flat items.
A link to plans will be added right here when I get to a real computer.
I get some free time at work every now and then so to stay busy I like to make tools that will make my life easier.
Sometimes we need to drill flat or irregular pieces that either won’t fit in a regular vise or are such that you need to raise and lower the head. This can be time consuming and this leads to people taking short cuts, the most common of which being holding the item by hand.
Looks like this:
These were sold as cast iron castings and also mild steel and tool steel by various manufacturers over the years, and were quite expensive for what they are and bring a premium on the used market.
I’ll be making this out of A2 tool steel and hardening, then drawing back to 45-50 Rockwell, but that is mostly because I can.
So here we go!
I skipped ahead a bit as showing pics of bandsaw cut bar stock just seemed unnessary.
Here you can see the jaws of the vise cut and milled to size and profiled. The steps in the jaws offer another height for clamping your part similar to using parallels in a milling vise.
Next up was drilling and reaming the holes for the alignment bar and the screw. This is done with the parts ganged up in the mill to ensure the holes line up.
Next up, tapping the 1/2”-10 ACME thread and making the rods.
OneDrive
Looks like this:
So here we go!
