Above 1200 Sq/FT building my BIG PARTY garage
drivesitfar
Amazing restoration Don!! Glad you finally figured out the handle issue. The phone booth is really moving forward and it should look awesome in the new spot you made for it.
Stay cool!!
D
don long
southern california
Back onto the Phone booth today.
i managed to get primer on the door grid and get the back panel ready to paint the front side of it.
And as long as I was going to spray some primer today I decided to get the double oiler cart ready for some primer. That meant taking the 2 pumps and wheels off the cart and also I removed the 2 cover caps to give me a cleaner working area.
The door grate primed (one side)
The back panel before sanding for paint for paint
The double oil cart in primer
garagenvy
Could you imagine the cost and logistics of building a cast iron phone booth in today's world, we'll never see stuff like this again. Looks great Don.
About $1 a pound cast in India (even cheaper than China). That would make a raw (750kg) booth about $1500 + shipping and finishing vs $3-5 grand for an original. The Brits made the earlier ones out of concrete.
D
don long
southern california
I think this phone booth project is more work than actually building your barn!
H. B.
You are right so today I went out and started building another storage shed to replace the old one that was on the property when I bought it
20' x 32' x 15' high at the peak
Yes Jim you are right.
That's what makes saving these things so rewarding, not to mention the fun in having them around the property.
D
don long
southern california
I've been working on the western town a bit this week getting ready for the B I G G.J. birthday party!!!
The town needed an entry sign so I put up the posts for it. What do you guys think
Next I need to bend 2 long angle iron pieces into an arch and get some steel letters cut that spell L O N G HO R N R A N C H
D
don long
southern california
Worked on the phone booth all day today while tree guys were working on the trees that hung over the BPG Man they were noisy
I've managed to get the inside of the right panel smoothed and the pits filled before applying a good coat of primer.
I have the first coat of primer on the center panel of the door so I'll block sand and prime it again before painting the inside
Each of these panels are so heavy that it takes the fork lift to move them from the shop to the booth and back again.
I'm not sure how I'm going to stand them up and bolt them to the base yet
D
don long
southern california
The tree guys butchered my trees today. I hope they grow back and don't die.
We had the biggest one removed and tomorrow they will grind the stump away
They were cutting the stump down 1 piece at a time. I think that their chain saw was too small to cut any bigger pieces.
I found a picture of the trees from a couple of years earlier. You can see the center tree reaching out over the roof of the BPG.
Thats why we had it removed
bugnut
Central Ohio
Don, you could make the Big GG party an assembly gathering for the phone booth. Then you'd have a bunch of folks arguing over which wrench brands to use, what kind of fasteners, what color to paint the bolts, which panel should go on first, who holds the light, ugh, uh never mind!:ROFLMAO:
drivesitfar
Looks like busier than ever. You make primer look better than most of us make our finished stuff look.
I can’t believe you got those logs up and standing (how deep did you dig the holes?) so I’m sure you’ll figure out how to put that old phone booth together.
Best of luck getting all these projects done and even though I can’t make the official GJ party next month I’m hoping to be down your way next spring.
Here’s to good health for you and your bride and hoping Pat is doing ok too.
D
don long
southern california
Just thinking about the G.J. birthday party guys
WE ARE 6 WEEKS AWAY FROM A GREAT EVENT AT THE BPG. SO BE SURE THAT I HAVE A MAILING ADDRESS TO SEND OUT THE INVITATION WITH ALL THE INFO FOR THE PARTY A P.M. WILL DO IT
D
don long
southern california
What happened? Cracks due to the heat cycling or termites? I'd imagine both are an issue there(?)
Water rot from the water seeping down between the brick wall and the deck
Only lost the end board across the front of the deck but had to remove all the boards in 2 sections and rebuild the framework
It’s only 102 degrees today
