How's the inner tie rod tool set?
Yeah right, just pretend to be reviewing a HF hoist when in reality you just wanted to make us all machine tool jealous.
I do...pretty good with certain exceptions. Slightly sand or grind the flat ends of the handle hex keys to give them sharper edges that will bite into the screws....only use the ball ends for speed removal of already loosened screws. You may be tempted to use a ball end in a deep place and you may get away with it a few times but eventually you'll wish you had just got out the hex socket and an extension for your ratchet wrench. These tips may actually apply to all hex wrench sets but they certainly apply to these....I can't remember the exact make up of your bike stable, but if you have any Kawasaki s in the mix the ball ends will round out (if used for loosening, not spin out) those wide headed 5MM socket screws that Mama Kaw' is so fond of using.Anyone have these? I need these all the time for the motorcycles and this price is good.
Ball End Hex Key Set
That’s exactly what I needed to know. Thank you. And I have one Kawsaki, two Suzukis and one Honda.I do...pretty good with certain exceptions. Slightly sand or grind the flat ends of the handle hex keys to give them sharper edges that will bite into the screws....only use the ball ends for speed removal of already loosened screws. You may be tempted to use a ball end in a deep place and you may get away with it a few times but eventually you'll wish you had just got out the hex socket and an extension for your ratchet wrench. These tips may actually apply to all hex wrench sets but they certainly apply to these....I can't remember the exact make up of your bike stable, but if you have any Kawasaki s in the mix the ball ends will round out (if used for loosening, not spin out) those wide headed 5MM socket screws that Mama Kaw' is so fond of using.
You're welcome, it seems you've cut back by at least 33%...hard for me to believe you and I have the same number of bikes* and the same manufacturer ratio numbers when my garage is not even 5% the size of yours. Of course I can barely get around in mine and you can throw parties in yours. I'll bet you've probably still got me beat in total actual engine cc displacement too.That’s exactly what I needed to know. Thank you. And I have one Kawsaki, two Suzukis and one Honda.
LOL I had one of those I got it in a pinch and it's like the battery socket never really made good contact.. I forgot how long I had it but I know the clear cover over the COB LED's ended up coming off, at that point I just threw it in the trash.This is a fail. I bought a few of them and I liked them at first but they have all started to fail. Junk.
https://www.harborfreight.com/215-lumen-magnetic-pocket-work-light-58569.html
Great! thanks Jayemm!You can get a kit with over 20 pieces and both a L/H and R/H tool for about $20 on ebay. There's a bunch for sale.
22PC Disc Brake Caliper Wind Back Tool Kit Piston Pad Compressor Rewind Tool Set | eBay
Find many great new & used options and get the best deals for 22PC Disc Brake Caliper Wind Back Tool Kit Piston Pad Compressor Rewind Tool Set at the best online prices at eBay! Free shipping for many products!www.ebay.com
You are welcome!Great! thanks Jayemm!
Correct, they are to keep it centered and the base away from the casters. If the base is up against the legs, I couldn’t turn the machine easily because the casters couldn’t swivel.What are the c-clamps and aluminum stock for, keep things centered? I realize it's only an inch off the ground and pretty safe. And looks like the boom extension is in the "1 ton" position. lol Pretty impressive for that thing.
I removed the legs. There are two pins that hold each leg on. With the legs removed, I could roll the rest out from behind.How did you manage to get the hoist out from behind the mill once you moved it into the corner?
Haha, I am a sucker for old tools. As for the cactus, not native to Michigan, but I have had it since I was 5 years old. As for the hoist, I was pretty surprised how well it did with the lathe. It’s a short 5’ long bed, but it fit right inside the legs of the hoist when balanced. Easy to move. The mill… that was more difficult, but it got there. That wells index is a beast.Yeah right, just pretend to be reviewing a HF hoist when in reality you just wanted to make us all machine tool jealous.
Mission accomplished!
Hate beam aimed at your cactus, let us know when it dies.
regards, Joe King![]()
HF bit holder. Neither pass nor fail, just minimally functional until I find or make something better. It needs to be deeper and/or have skinnier diameter holes. It holds short single-ended impact bits OK, but longer bits and double-ended Japanese bits flop around. I've seen this bit holder sold by many companies.
I have one of those, sold by someone else. The bits are a loose fit in the holes, but they're noticably closer than that.HF bit holder. Neither pass nor fail, just minimally functional until I find or make something better. It needs to be deeper and/or have skinnier diameter holes. It holds short single-ended impact bits OK, but longer bits and double-ended Japanese bits flop around. I've seen this bit holder sold by many companies.
Thanks. The holes do look skinnier but it looks too shallow, maybe barely 7mm(?) deep, for double-ended Japanese bits which don't have the 1/4" section all the way to a flat base like the single-ended hex bits on the first row right and the western (9mm anvil) socket bit in the middle in my pic. I think that's the reason why Japanese bits fit ~40mm deep into my Anex & Vessel interchangeable bit handles.This is the one I have saved in my cart for future purchase. Looking at the photos in the reviews it appears to hold the bits a lot better than that HF one:
countycomm.com
countycomm.com
You should check out these.
On The Go Bit Holder - Non Slip ( Coming Back Soon! )
Jump On The Waitlist Now To Be Notified! The Silicone Bit Holders are just what you need to keep 37 of your 1/4 inch screw driver bits organized and available for use in the field or on your bench. Why are On The Go Bit Holders so cool? They are made of a solid block silicone with chemical and...countycomm.com
They have them in orange or glow in the dark silicone.
I’ve got 2 but haven’t actually used them yet.
I've been thinking about it for my ebike/trailer. Between the bike and trailer, I've got a number of different Allen fasteners and hex bolt sizes and of course screws. It seeks like I could cover all of them with this kit and a few sockets.Icon micro-ratchet set, PASS
Also functions as a t-handle and screwdriver.
It's perfect for my motorcycle tool kit. Replaces the ratchet & allen wrenches on the right, saving space and weight. I looked at a ton of similar tools and this one rocks.
I think it's manufactured by High-Five and sold under a bunch of different brands.
https://youtu.be/tyvhq65iJ8s
quinn pistol grip wire stripper
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!www.harborfreight.com
haven't had them long enough to see how they hold up, but so far they work as they should, so a PASS for now. if they do wind up breaking i'll update. made in Taiwan
What gauge wire do you use this to strip? Most everything I do is 10-18 ga.after almost a year, so far so good, still working just fine. just used them again this afternoon
I have one of those, and the Workmate version as well.I needed a light duty workstand for use in the 2nd garage. I've got a Workmate hanging on the wall in the other garage but it's a hassle to drag it back and forth as needed. So, I bought this:
Surprisingly sturdy given it's weight. I'll use it as a small portable workbench when I don't want to make a mess in the garage.
I give it a pass, especially for $23
That's nice. Reminds me of the old Sun VAT 40's? Does it test starter draw tooI used my HF Memorial Day 25% coupon to buy this Viking 1000A carbon pile battery tester, for $150 plus tax. I like it. The analog meters are properly calibrated, when checked against my Fluke meters. This unit is a higher quality carbon pile than the Chicago Electric 500A carbon pile I bought from Hf about ten years ago. This is a PASS.
thoughts on the painless harness? you can message me to get this off this threadsame size, i just used it running a painless harness in my truck.
If a harness is painless, is it really a harness? @PelicanPinesthoughts on the painless harness? you can message me to get this off this thread
