The Harbor Freight PASS/FAIL Thread...
fartymarty
Fort Worth
Anyone have these? I need these all the time for the motorcycles and this price is good.
Ball End Hex Key Set
I do...pretty good with certain exceptions. Slightly sand or grind the flat ends of the handle hex keys to give them sharper edges that will bite into the screws....only use the ball ends for speed removal of already loosened screws. You may be tempted to use a ball end in a deep place and you may get away with it a few times but eventually you'll wish you had just got out the hex socket and an extension for your ratchet wrench. These tips may actually apply to all hex wrench sets but they certainly apply to these....I can't remember the exact make up of your bike stable, but if you have any Kawasaki s in the mix the ball ends will round out (if used for loosening, not spin out) those wide headed 5MM socket screws that Mama Kaw' is so fond of using.
tez929rr
Welfare, TX
That’s exactly what I needed to know. Thank you. And I have one Kawsaki, two Suzukis and one Honda.
fartymarty
Fort Worth
You're welcome, it seems you've cut back by at least 33%...hard for me to believe you and I have the same number of bikes* and the same manufacturer ratio numbers when my garage is not even 5% the size of yours. Of course I can barely get around in mine and you can throw parties in yours. I'll bet you've probably still got me beat in total actual engine cc displacement too. :(
......and just to stay on topic a bit more, as a follow up, I still recommend the HF transmission jack for both a bike lift and a bike dolly if adapted properly to the bike it is used for. I'm still using mine and it is a definite pass for this purpose:
https://www.harborfreight.com/450-lb-low-lift-transmission-jack-61232.html
https://www.garagejournal.com/forum...-pass-fail-thread.27192/page-253#post-8421343
..of course only those of us with a smaller garage would need such a thing. :p
*yes I do count my Honda Trail 90 (125cc Chinese clone engine) as a bike, the state does, the insurance company does, that's good enough for me. ;) (y)
subarub4
Connecticut
Chance
New England
vanapplebomb
Holland, MI
What are the c-clamps and aluminum stock for, keep things centered? I realize it's only an inch off the ground and pretty safe. And looks like the boom extension is in the "1 ton" position. lol Pretty impressive for that thing.
Correct, they are to keep it centered and the base away from the casters. If the base is up against the legs, I couldn’t turn the machine easily because the casters couldn’t swivel.
And yes, highly not recommended, but it is in the 1 ton position. The 1.5 ton position was too close to the frame to balance the machine.
vanapplebomb
Holland, MI
Yeah right, just pretend to be reviewing a HF hoist when in reality you just wanted to make us all machine tool jealous.
Mission accomplished!
Hate beam aimed at your cactus, let us know when it dies. :moon:
regards, Joe King😇
Haha, I am a sucker for old tools. As for the cactus, not native to Michigan, but I have had it since I was 5 years old. As for the hoist, I was pretty surprised how well it did with the lathe. It’s a short 5’ long bed, but it fit right inside the legs of the hoist when balanced. Easy to move. The mill… that was more difficult, but it got there. That wells index is a beast.
rick carpenter
Huntsville, East Texas
HF bit holder. Neither pass nor fail, just minimally functional until I find or make something better. It needs to be deeper and/or have skinnier diameter holes. It holds short single-ended impact bits OK, but longer bits and double-ended Japanese bits flop around. I've seen this bit holder sold by many companies.
Madjik Man
This is the one I have saved in my cart for future purchase. Looking at the photos in the reviews it appears to hold the bits a lot better than that HF one:
dscheidt
I have one of those, sold by someone else. The bits are a loose fit in the holes, but they're noticably closer than that.
rick carpenter
Thanks. The holes do look skinnier but it looks too shallow, maybe barely 7mm(?) deep, for double-ended Japanese bits which don't have the 1/4" section all the way to a flat base like the single-ended hex bits on the first row right and the western (9mm anvil) socket bit in the middle in my pic. I think that's the reason why Japanese bits fit ~40mm deep into my Anex & Vessel interchangeable bit handles.
rick carpenter
I separated the magnetic bottom and added about 1" with plywood & hardboard. I plasti-dipped it hoping enough spray would get into the holes to tighten how the bits fit. It's better, I'd now say PASS with MODS.
mashguy4077
Springville Utah
mashguy4077
Springville Utah
You should check out these.
They have them in orange or glow in the dark silicone.
I’ve got 2 but haven’t actually used them yet.
rick carpenter
Thanks. Pretty interesting, tapered holes in a silicone block to provide secure bit fitment. And for a good price. Please try them out and let us know how well they work.
Prospecter
Maine
I have several HF bit holders. They don't seem any different than others I bought (for color variety). Big Pass on the HF. I love 'em. Nice fit and right hold. Not too loose. Not too tight. I use them in shallow drawers (upright), so anything really long is lying flat in the drawer.
wingnutx
Phoenix, AZ
Icon micro-ratchet set, PASS
Also functions as a t-handle and screwdriver.
It's perfect for my motorcycle tool kit. Replaces the ratchet & allen wrenches on the right, saving space and weight. I looked at a ton of similar tools and this one rocks.
I think it's manufactured by High-Five and sold under a bunch of different brands.
https://youtu.be/tyvhq65iJ8s
GeoBruin
I've been thinking about it for my ebike/trailer. Between the bike and trailer, I've got a number of different Allen fasteners and hex bolt sizes and of course screws. It seeks like I could cover all of them with this kit and a few sockets.
emeraldcoupe
spring hill, florida
quinn pistol grip wire stripper
haven't had them long enough to see how they hold up, but so far they work as they should, so a PASS for now. if they do wind up breaking i'll update. made in Taiwan
after almost a year, so far so good, still working just fine. just used them again this afternoon
lolaetype
North Western Arkansas
I needed a light duty workstand for use in the 2nd garage. I've got a Workmate hanging onthe wall in the other garage but it's a hassle to drag it back and forth as needed. So, I bought this:
Surprisingly sturdy given it's weight. I'll use it as a small portable workbench when I don't want to make a mess in the garage.
I give it a pass, especially for $23
BreeStephany
Oregon
I have a pretty nice MAC tap & die 'super set' for my home toolbox, but wanted a small, quality tap & die set for my work truck (electrician) for those random moments where I need something other than the standard 6-32,8-32,10-24,10-32 & 1/4-20 drill taps in my Greenlee DTAP kit.
I recently picked up the ICON 41pc. SAE drill & tap set from Harbor Freight, which with a 25% off coupon, wasn't too bad.
I have been pleasantly surprised with the quality of the taps & dies. The centering adjustment on the die wrench isn't comparable to tool truck quality and there were some surface imperfections on the outside of the dies, but so far the taps & dies have been easily cutting clean threads and don't flex like cheaper sets.
For an 'occasional use' set to keep on the truck, its a PASS, especially for $98.
Outahere
Idaho
I used my HF Memorial Day 25% coupon to buy this Viking 1000A carbon pile battery tester, for $150 plus tax. I like it. The analog meters are properly calibrated, when checked against my Fluke meters. This unit is a higher quality carbon pile than the Chicago Electric 500A carbon pile I bought from Hf about ten years ago. This is a PASS.
Kenstone1
I needed a light duty workstand for use in the 2nd garage. I've got a Workmate hanging on the wall in the other garage but it's a hassle to drag it back and forth as needed. So, I bought this:
I have one of those, and the Workmate version as well.
The HF is way sturdier, but I stiffened up both by welding the joints of the front and back cross braces and legs.
The Wmate has big gaps, so I laid a finish nail in the joints/gaps and welded over them.
I used the HF as a make-shift welding table for a while.
I put wheels on 2 legs and a handle opposite so I could roll it outside to weld:
Sorry for the bloviation, way too much info. :oops:
zendriver
Indiana
I've had the inexpensive reliable HF automotive battery/charger tester for years, but was looking for something a bit more advanced, to use as backup.
Wasn't even on sale, but not a terrible price and seemed to fail bad batteries and pass good ones, verifying charging health, on the systems tested. There are similar designed testers on youtube.
PASS would have been even happier if it was on sale (that's life).
dagofast
The QC in AZ
I finally gave up trying to find a cheap portaband saw at yard/estate sales and bought one of these: https://www.harborfreight.com/10-amp-deep-cut-variable-speed-band-saw-64194.html for a buck twenty.
My plan was to also pick up a SWAG table to mount it to but then Harbor Freight introduced these: https://www.harborfreight.com/universal-portable-band-saw-benchtop-stand-59640.html It is pretty much a steal at $99.
It does the SWAG table one better by not just being a vertical bandsaw, it also lets you use it as a horizontal cut off saw that does straight and miter cuts. It takes a little fiddle farting around to get the saw lined up just right in the stand and a little more farting around with the on/off lever to activate the trigger switch on the saw but once you get that all done, it works a treat. It also comes with a table when using it as a vertical bandsaw and various brackets to mount a Bauer, Hercules, Milwaukee or DeWalt brand bandsaw.
I'd rate both as a pass.
bubinga
That's nice. Reminds me of the old Sun VAT 40's? Does it test starter draw too
Toyo72
Fortress 2 gallon air compressor - PASS
This has been a really nice addition to the garage, have had it for 2 years and it has been flawless. Runs very quietly, fills up to pressure quickly when you power it up, runs small air tools like my Metabo finish nailer with ease.
Bauer 6 gallon wet/dry shop vac - PASS
Bought this hoping it would last through one construction project, and it has been surprisingly durable through lots of abuse. Sucked 15 gallons of water, uphill, out of some buried conduit. I've vacuumed concrete dust slurry, drywall dust, and lots of construction cleanup mess with this thing, and it just keeps going. Guess I should replace the filter...
Chicago Electric 4 in. Biscuit Plate Joiner - FAIL
It works, but way too much slop in the mechanism. Not for precise work. I returned it.
zendriver
Indiana
ZR15s OBD2 Code Reader - PASS​
Always been a fan of inexpensive automotive diagnostic equipment, especially ODB2, which I upgrade over time, as they add more features. This model has a large screen, lot of features and luckily, plenty of keys to easily maneuver through them. Realy like the battery/alternator tests, ID's vehicles easily and stored codes from multiple vehicles if the batteries are installed in the unit. TPMS support on some level, on a '14 Highlander, bunch of info, not sure yet how to decipher. connect to the repairsolutions2 site got a bunch of info on recalls, repairs parts and service bulletins. Free at least for now.
Just a fun piece of high tech test equipment. Used 20% off ITC coupon, grabbed the last one they had.
Maybe it's just me(or the heavy ply tire), but I give the Pittsburg tire plug kit - epic FAIL
The handles are strong but the tool metal is soft and flimsy. The adhesive on the plugs was like freshly chewed sugar-free gum, just a mess. runny glue.
XJSuperman
Central Iowa
I bought the new chopsaw frame for the portaband. I am not impressed. It's been a real pain to setup so far. I made one cut that was pretty crooked, after spending a lot of time checking for square and clamping the saw in place.
There's no great way to clamp a workpiece without a specific clamp that isn't included. C-clamps doesn't work, and the frame floor doesnt allow for typical locking visegrip type clamps. The on/off trigger setup is pretty useless, but maybe more finnageling and I'll get it figured out. The stand is adjustable but fitment still manages to ****. The blade should easily align with the opening in the frame floor, however it is physically impossible to attain that when using the Bauer saw. I like the Bauer saw, but in the frame it just isn't working well. I'll update if the weekend brings about better results.
