The Harbor Freight PASS/FAIL Thread...
zendriver
Indiana
Picked to the Fortress ultra quiet 1 gal air compressor. $112
Built very solid, well designed and for sure runs quiet, pumped up to 135psi is about 60 seconds. Gauges look sharp and regulator works solid. Nice power cord and hooks to wrap up for transport.
Bummer that the tube frame was mis-formed enough, so only 3 feet sat on the floor, unit would rock, although it did not even flinch, when pumping up.
It would have functioned just fine, but I was annoyed, so we took the unit back for a replacement, which sits just fine.
Pass in spite of having to swap out one unit.
https://www.harborfreight.com/1-gal...jkg_VMpigoDdkk-wDy75FvL4ZItaBoiEaAkkvEALw_wcB
I have to update this, as it did not work out.
It is a nice compressor and I can't give it a "fail" but it's low output is not really convenient for airing a pickup truck tire or using blow gun. Maybe good for airbrushing, IDK
I returned it and they gave a full refund (no restocking charge) since I agreed to buy a larger model.
Went with the 2 gallon, that had similar performance as my old Cman, comes with aluminum tank and at 37 pounds, did not want to carry anything heavier.
Also a good compressor, been holding full pressure for a week now PASS
https://www.harborfreight.com/2-Gal...-Hand-Carry-Jobsite-Air-Compressor-64596.html
danny_barkley
FL
Harbor Freight 20 Ton Press Help
I bought a HF 20 Ton press a year or so ago, maybe two. I have need for it and discovered it is missing some parts.
I am going to call the HF folks and see what they will do. But I may have to source them myself .
The parts I am missing are the two springs and the two eyebolts.
If you Have this press, can you measure these parts for me.
Need the spring length and diameter off the press and the eyebolt specs.
getbent4x4
buy a new one, close eyes on selection for return. PN match if not close eyes on which box is getting return parts put in.
skulldrinker
Bolingbrook, IL
Yeah i would in the store tell them the story. If they dont give them to you i woukd do the buy and switch move. I would even tell the guy to his face to save you the trouble that's what you're going ti do.
I told my store i was going to buy and switch one of those 12 miter saws because the first one was broke in the box and he said i did it and he just gave me another one. He knew i was going win.
Sent from my SM-N960U using Tapatalk
danny_barkley
FL
I called them today and they rummaged in the back and found some for me. Very nice about it since I was out of warranty and had not bought into their extended warranty. I did buy the air bottle jack from them though today. They could not find that I had bought the press from them. Something slipped up there.
teal95
Grass Lake, MI
61600 2 ton underhoist safety stand - Fail. Can't be assembled as directed and even with moving some parts it still takes brute force. The problem is the leg braces are too long. When I attempted to assemble it as directed when I put the upper braces on the tops were way too far apart to get the top of the column. For immediate use I bolted the top of the column to the legs, then put the angle connectors and the plate on the bottom of the column but swapped the connectors to have the long leg horizontal, then used my legs to spread the legs far enough apart to get the cross braces on.
steve
Coach James
Sandhills of North Carolina
Re: Harbor Freight 20 Ton Press Help
Did you put it together when you bought it and check for all the parts?
Coach
jgromada
Maryland (between DC & Balt)
These Bremen locking long nose pliers @ $6.99 - coupon are a PASS. Bought a few of these.
The fit is an improvement over the standard Pittslburg equivalent
This is a new item i want to check out . Its only $.99 but maybe a new candidate for the Freebees?
subarub4
Connecticut
Looks like the HF card processing machines are down was going to pick up an axle socket (32) and another deep socket set I think I’m going to get something better then the cheap set but I already knew that lol.
I’m not sure about the cordless impacts I might just stick with my Milwaukee’s since I own a lot already.
ecotec
I like the the Roloc mandrels. They are much cheaper than the other brands, especially when there is a coupon for 30% off products under $10.
I would buy a few extras, just in case one fails during a project.
My take is that they are more than good enough, until one finds a stash of name brand mandrels at an estate/garage sale.
subarub4
Connecticut
Came close to getting the 1/2” impact sockets but I just hate that they just don’t come with cases I ended up ordering from Amazon.
I hate how no 23mm wrench or socket unless you buy the $99+ set
slackdaddy1
Southern MD
Bout one 2 years ago, if memory serves me, you have to add your own pig tail or cord end? I know I made up a long cord that plugs into my standard welder outlet.
Works just fine,, heavy as hell but did what I needed it to do.
A couple thoughts if I had to do it again.
I would have REALLY like a set of deep tongs, but sourcing a set was expensive.
an all in one unit like that is HEAVY and hard to manipulate.
If I was to do it again,, I would have combed CL and Marketplace looking for an older used machine with stationary transformer, cables and separate tongs,, hopefully with multiple different size/reach tongs
Anybody use the #61206 220V Spot Welder? Does it work decent?
adamz
Cordova, TN
Admiral 12in sliding compound miter saw: pass!
I recently put down new baseboards, quarter round, and crown molding. I was using an old Ryobi 10in compound miter, and ran out of cut room on the crown (was using Kreg crown jig) so figured this was a nice excuse for a new tool. Required very little adjustment out of the box and was working my way through the rest of the crown molding in no time! The laser needs adjusting if you want it for something more than a ballpark reference, but I don’t use the laser for accuracy so that was a non issue for me. I paid $175 with a coupon, very happy with my purchase.
Wanna Ride
Pittsburgh Automotive, 450 lbs. Low Lift Transmission Jack #61232 (or #39178) normally $99.99, but with a standard 20% coupon, I paid $79.99.
I specifically bought this when I installed my suspension lift on my truck, to lower and raise the front axle. Worked flawlessly, and I had no issues with it. Not something I use often, but well worth the investment. It's one of those items that, once you have it, you find other uses for it when working on other projects.
https://www.garagejournal.com/forum/attachment.php?attachmentid=992214&stc=1&d=1585468913
skulldrinker
Bolingbrook, IL
This caliper just quit working with occasional use. Short lived in my opinion.b0d516c78594bea5cb8daf8ef6b8e962.jpg
techieman33
Kansas
I gotta ask the obvious. Battery?
That's my thought too. It's pretty common knowledge that most if not all of the cheap calipers out there never actually turn off. The display might turn off, but they're still always measuring. It doesn't take long to drain the batteries. Unless your using them everyday you should take the battery out when it's in storage.
Motorman55
South Jersey
That's what I do too. Only takes a minute.
fartymarty
Fort Worth
I have to second the recommendation for this Jack. Certainly not for daily usage in a transmission shop, but it also adapts well to other purposes. In my case it's used for a Dual Sport motorcycle dolly. Most small motorcycle dollies require a center stand on the bike, even then they run around $200. Harbor freight makes a side stand dolly but it's rather large. My DR650 doesn't have a center stand and I've adapted this jack as both a bike jack and dolly. I added some coupling nuts to the top as locating pins that help align the dolly in the foot pegs and keep the bike from sliding off of it. I also purchased a HF telescoping 1/2 drive ratchet as a dedicated wrench for the dolly/jack. Also put some adhesive backed rubber strips on top of the jack/dolly.
For my purposes, definitely a pass. :thumbup:
larry4406
Northern Virginia
I recently bought the Maddox Disc Brake Pad And Caliper Service Tool Kit 11 Pc SKU 63264 to retract the rear calipers on a 2012 Ford Focus.
https://www.harborfreight.com/disc-...3264.html?_br_psugg_q=disc+brake+caliper+tool
It worked well, seems well made, not a complicated tool. Not a tool one needs often. Normally I rent these from the auto parts store that sells me the pads but no one had the tool this time.
With a 20% of coupon, it was $40. It will now sit in the tool box till the next brake job. The ceramic pads on the Focus have lasted 100k between replacement which is impressive. I installed the first set of brakes at 109k and now this set at 214k. I drive a lot of highway miles which explains the atypical service life.
jim faston
I had one go south too. The battery contact fell off the board. I found it and was able to solder it back on. Also, the battery covers on a couple of mine have deformed and no longer stay on without tape.
Rocket3004
This isn't exactly a pass/fail post so forgive me, but I was looking to pick up the Pittsburgh leak down tester (I will use it probably once and never again... if I could rent/borrow one, I would) but it seems like it is being phased out in favor of the more expensive Maddox line (which may be a better product - not sure). Dunno if this is similar to the 'better' Icon brand being phased in.
Do y'all think this is a one-off move vs. move to a 'better tool' vs just moving overall to more expensive stuff in general?
JRC3
Southwestern OH
Do you have and Advance or Autozone close by??? As usual, it's hard to give advice without knowing at least a region...
Loose Ctrl
Upstate SC
Post hole auger with 6 inch auger item #56257. PASS
I've read many mixed reviews on this post hole digger. Youtube videos lean more toward it being a good buy. I bought one and it cost $200.18 delivered with a coupon price of $179.99. I couldn't wait around until it drop to the $150 range.
I was quiet surprised by how capable this machine really is. The depth of digging is a bit misleading. Somewhere I read it's 31 inches and other places say 36 inches. If you bury the power head in the ground, you may get close to 36inches. From the very tip to the top of the auger spiral was 24 inches exact. With the tolerances being pretty loose on these Chinese machines, it could vary. I would measure yours before poking holes in the ground. I wanted 30 inch depth for my privacy fence posts and I got that.
As far as how it ran and the power, it will dig like crazy once it gets a good bite. I have red clay in the area where my fence is going. Luckily, we've had a lot of rain. If had been dry, I don't think anything less than a 5hp two man unit would have got the job done. I ran into a rock spot. As long as the rocks aren't fist size, it pulled them up and out of the hole. It wasn't happy doing it, but it did do it.
I was impressed with how easy it starts. I mixed the gas and oil in the little container that's provided. It's a 25:1 mix. They recommend adding fuel stabilizer. I did and also used non ethanol gas. Using the bottle as recommended, I had just a faint hint of two stroke smoke. Not even enough to smell it unless the wind blew just right.
The first start up, I pumped the primer bulb five times to fill it up. I set the choke to start, and turned the kill switch on. She started in three pulls without using the throttle. I switch the choke to run and she purred along nicely. With about a minute or two to warm up, she revved to full throttle instantly.
I put her away until the next day. I left it upright leaning against the corner of my out building. All I had to do to start it up was set choke, turn on the kill switch, two pulls with no throttle, and she started right up. As we ran the machine, it got easier to start.
I didn't run the machine to hard. We may have gotten called away, so we did one hole and set one post at a time. Where the fence is going, my neighbors like to back into my yard and they would have collapsed the holes had I had to leave and leave the holes open. If I would have set the posts in the holes, and left them, they would have pulled the posts up and stole them. They really are not nice people.
All in all, I wouldn't go with a larger auger bit with this power head in my area. With the tightly packed red clay we have, I did have to really put all I had into keeping the power head from spinning out of my hands. I raised the machine every 6 inches or there about to clean out the hole. I'm not tall at 5'8" but I am a stout fatty at 230lbs.
I set 8 posts 30 inches deep and used have of the mixing bottle full of fuel so maybe a cup of fuel total. I could see this machine doing 20-25 post holes per tank. Maybe more in nice soil.
Wanna Ride
Good review, thanks for sharing. I've looked at that before and wondered how well it was. Geez, at that price, it almost makes it disposable, if it only lasted long enough to do one big job. When you figure a decent set of manual post hole diggers with fiberglass handles is about fifty bucks, and how much time and effort it can take when doing it manually, in a tough area. It's a no-brainer when you have a couple dozen posts to set. I only have three posts to set on an upcoming project. And prior to that, I've only had one post in almost thirty years to set, so I can't quite justify the cost. But if had more to set, it'd definitely be worth it. It looks like an extension could be easily made and adapted, to get deeper.
Harbor Freight really has stepped up their game in the last few years.
JRC3
Southwestern OH
You still need a post hole digger and a spud bar. I've had a similar Earthquake model for over a decade and every time I use it it still requires all the manual tools to complete the task. The auger doesn't get all the dirt out and there will always be rocks and roots in the way. But the auger certainly does most of the work.
Kent_B
MI
Pittsburgh wobble extension set (item 61278) --PASS
I used the 3/8 and 1/4 inch drives from this set while changing spark plugs on a 2008 Outback 3.0, The extensions retained sockets well without being too tenacious and provided a decent angle working in very tight quarters.
Wanna Ride
Good. Good for you.
Carry on.
Loose Ctrl
Upstate SC
My rental place wanted $200 per day for a two man auger. The use of this one will be spread out over the year so it was worth it to me. I can't comment on how an extension would work. Anything is possible though.
I did need a post hole digger to clean out the loose material that fell back in the hole. I didn't need a spud bar, All though if I'd hit a patch of rocks or roots, I may have.
Coach James
Post hole auger with 6 inch auger item #56257. PASS.....
I bought that auger a few months ago and it has been great for me too with one exception. Maybe I'm using it wrong, but it seemed like the fumes blow straight up to my face. Aside from that, no problems. The first use was putting several holes, 24" deep in gravely ground for a perk test. Auger was $159 on sale, perk test was $650. Since then, a bunch of holes for fence posts.
Coach
Loose Ctrl
Upstate SC
Coach
Yeah the cooling air does redirect back up at you. The exhaust is blown away from the machine if you're holding it with the throttle on the right side.
