I unfortunately hired an electrician that turned out to be hard to work with. Anyway, I thought he mentioned having shared some neutrals in the panel, but then he claimed that he didn't. Initially he had a couple of 20 amp breakers with handle ties, then he rearranged the breakers very quickly and none of the have the ties anymore. Basically, what is the easiest way to check to see if there are shared neutrals in the panel. Is there a way to do it using a multi-meter?
One note, the lines are fed in though the top and I can't peak in that part of the panel without taking off the meter, which I don't want to do.
