The Everything 3D Printer Thread
kaymccampbell
Upstate New York
Kay, I'm convinced you're really a 20 something year old influencer.:D
Oh, how I wish. The one farm went from horses providing power for most everything through post-war, when I was born, to iron wheeled tractors, I want to say it was something F, in the 50-60's, to rubber tired tractors, John Deere, in the later 60's. The other farms went from horses through the war, to sold to developers.
jeepxj
do you think the paver makes a difference? I've considered putting one under my x1 but it's been printing great without it.
not sure. these shelves are so weak they bow badly. so i figure more weight and some mass will certainly not hurt.
laser3kw
northen IL
I had a shelf unit like that. It was rickety from the start. I squared it up and welded all the joints. On a different shelf, I used 1/4" plywood and screwed it to the back and horizontal shelf members for stabilization. Then, I got smart and bought better shelving that didn't need all the extra cost and labor to make them substantial enough for my use.
jeepxj
when it was just about done. it sucked it up into the PTFE tube to finish. cutting it real close on these prints.
jeepxj
they came with the house, were near good power, and im lazy. so far doesnt seem to be impacting print quality. When we move i will get new heavy duty shelves bolted to the concrete.
jeepxj
welp the prusa mk4 arrived and i dont think im going to open it up. just listed it for sale. if anyone here wants it drop me a PM.
ER70S-2
I just got ahold of some polycarbonate carbon fiber filament which I'll probably use to print spare extruder parts first. Anyone ever use this stuff?
Poolshark314
MD
If you haven't already, you'll want to switch to a hardened steel nozzle. Most people say that filaments with additives wear right through brass nozzles
ER70S-2
Yep, I have 0.4 and 0.6 Nozzle Xs.
I just started messing around with the 0.6 and holy ****. You can cut print time nearly in half with it and 0.4mm layer heights. The prints still look great if they don't have a lot of fine detail. If anyone has not yet tried a 0.6 nozzle, I highly recommend it!
Poolshark314
MD
Yeah I was actually impressed I got pretty solid quality out of a .8 nozzle
Jehannum
Albuquerque, NM
I really disliked how the hardened steel nozzle forced me to slow down prints because of the lousy heat transmission as compared to the brass nozzles. I switched up to tungsten carbide nozzles instead, and have no complaints other than price.
All things being equal, I'd stick with brass, but since the kids expect it to be fire and forget, the tungsten is the choice for me.
AirMech#406
Got a call from DHL Friday. They were verifying my address so they could deliver the XL.
Delivered. I’m working out of town a couple days. Don’t worry, a friend set it inside shortly after delivery.
More to follow once I get it setup.
Very exciting!! Keep us updated.
sh944
Linwood, KS
For how cheap brass nozzles are, why not just buy them 25 at a time (like I do) and replace as necessary? Granted, there are some types of filament that can be fussy about the nozzle and brass isn't a great solution, but for filament that is just highly abrasive but otherwise prints well, it hasn't posed a big problem for me.
Fair disclosure, I am not running a 3-d printing production shop, so my needs could be different from yours.
Jehannum
Albuquerque, NM
That's exactly what I'd prefer to do, but then I get periodic questions from the kids (who absolutely love to put abrasive filaments through the machine) about why their prints look funny.
I figure it at least saves me a little bit of headache to just have a hard nozzle in there instead. It makes the availability much higher, and the tungsten basically allows me to run settings compatible with brass, so I don't have to maintain a unique set of slicer settings either.
It goes a long way towards making the machine fire and forget, which is good for my use case.
jeepxj
So how do i explain to the wife about the 320 lbs of PETG that will be dropped off in a month?
slodat
Central-ish, WA
Got back late this evening. Decided to check out the XL. It’s a BIG box:
Packed really well..
A few minutes of minor assembly:
Then run through various calibrations:
Then 90 minutes in support chat. The left Z axis stepper seems to have seized since it left the factory. They say they haven’t seen this failure. Because of this they need a few days to decide what they want to do. Support had me remove all the fasteners to lift the heat bed to verify the stepper does not turn.
This thing was a lot of money. And it has been nearly two years since I ordered it. (20 months I think.) A few paths forward were thrown out there by the support agent- I return, they evaluate, then either repair or send another. This would take 4-8 weeks. They send a motor and I replace.. but they don’t have instructions on replacing a Z motor. Even the kits come with the Z axis towers assembled.
Definitely leaving a bad taste in my mouth..
jeepxj
man what a bummer. the 2 head stuff it really attractive to me in the future.
ER70S-2
Most people just bump the nozzle temp up 5-10 degrees when using hardened steel nozzles. Did you try that?
AirMech#406
Man, that really *****. The XL has been so long-awaited I cant imagine the disappointment and frustration of having a trashed stepper right out of the box.
I jumped on the X1 Carbon band wagon to replace my modded Anycubic Vyper, but I am still eyeing Prusa for a future addition to my collection.
I doubt I would get the XL but I might dive in if they put out a CoreXY version comparable in size to the Mini or MK3S.
slodat
Central-ish, WA
My patience is starting to run thin. They haven’t responded in two days. This is a VERY expensive printer. :(
