I've had this old Sears compressor for the last three decades, my Dad didn't to take it with him when he moved to South Carolina so I've been using it since then and it's been very reliable but somewhat underwhelming as far some things are concerned.
So my brother and I kept an eye out on FB Marketplace and stumbled across a nice 60 gallon tank for $50. We picked it up and the it sat in the garage for a year or so until I figured out how I wanted to build it out.
Here it is in primer after I welded on the extension pad to better Mount the Harbor Freight 5hpcompressor pump.
I ran a hydrostatic test on it and it held pressure for 12 hours. This meant I could move onto the next steps in the project.
I built a bracket out of 3/16 plate, some 1 inch tube and angle iron to mount the Derale oil cooler that I'm using as an aftercooler for this project.
This is the extension that I welded onto the mounting pad so that the pump didn't overhang the centrally mounted pressure switch port and allowed me to center the entire assembly.
I bought a Vevor Motor off eBay to go with the Harbor Freight pump, and used Compressorsource.com to source the pulley for the motor and the pressure switch, as well as the new check valve for the tank. I utilized Amazon for the Derale oil cooler, and the moisture trap that I've installed between the cooler and the check valve.
This is how I ran the piping with 5/8" copper coming off the pump reduced down to 1/2" going into the cooler and 1/2" running down to the tank.
I moved it to its location yesterday and tested it out, after I ran it for 30 minutes with no load and then changed the oil. It took 4 minutes to go from 0 to 150 psi. The next step is to run my shop air piping and finish this project off so that I can get my blast cabinet setup for my restoration projects and for painting as well as air tool usage.
Overall I'm pretty happy how this is turning out so far.
