Looking for a bit case
Sanderguy777
midwest
I'm looking for a drill bit case (screwdriving bits, and maybe drills if they fit).
I really like the Dewalt ones with the dovetail system. Milwaukee is out, they're cases are junk (I like their packout stuff, but their bit cases are so bad).
Things I NEED:
1. Bit holders that can hold about forty 1" bits (30 at minimum). Organized, not stuffed into one bin.
2. Storage for a 6" extension, about 5 or 6" mini ratchet.
3. Storage for about five 2" to 3" bits.
Things I would like:
A. Storage for drill bits
B. A way to attach it to other cases.
C. Modular inserts (so I can move the bit holders around and adjust the setup).
Thanks
Aileron
outside
What gripes my *** is the drill cases. I have a dewalt 18 volt nicad and in that case you can put a bit oragnizer and a bunch of loose bits in it, and it still has the space designed to hold the drill securly. It was a hard case so when you carried it up on a roof and opened it stayed open and you seen everything in it. What they have now especially millwakee is a joke. You can't put anything in their hard cases and if you use a bag you have to dig. What makes it worse, they put a impact in the same case if you buy the set. Who carries them both going up a ladder to your jobsite when you only need one? They didn't just miss the boat with all these new designs , they sank the damn thing.
Sanderguy777
midwest
Big Dewalt case. Can attach to TSTAK cases and smaller ones on it
Big Dewalt case.
That's big, all right! Probably too much at this stage, but I'll definitely give it a shot. Thanks!
DeWalt. You already answered your own question.
They make a couple different sizes of the cases as well.
Thanks. Just picked up a couple small ones. Tragically they just don't offer the holders themselves, but I can live with this system.
I hate the DeWalt dovetail style. When you open the case the wrong way, they fall out and it's tragic.
Not as bad as the Milwaukee ones, not by a mile. They have the little inner boxes that look closed but aren't. They also have rails for bits where each slot is either perfect tension or completely loose. I can fix the rails galling out, it's the bits that are my gripe LOL (I lived with the bit holder issues for mlnths, but i only dumped that inner case 2x and that was enough LOL)
I think you could get by with the medium size DeWalt TSTAK case (DWAN2190). Then get a 3D printed organizer tray off Etsy and your set.
I'll take a look. Probably getting the big one, or just a couple small ones. Just depends on how they organize. But I'll keep the organizer inner parts in mind!
I'm blown away by their packout stuff. I have a bit of it, and you'd think the price would be enough to get some organization built in, but you can't even buy it separately for Milwaukee LOL! I like the little makers that pop up to fix the issues that creates, bur they're not cheap. (And that's an issue across all the box manufacturers, and bags are arguably worse, since you either make your own organizers, or buy a bag with it built in for 4x the price (or settle for the junk one with 10 pockets that fit nothing well LOL). Husky has a couple good ones, but they rival the drill cost!
But yeah, totally don't get the bags they have. My Dewalt came with a drill, impact driver, 2 batteries and a charger but the bag only fits all that if it's stacked on top of itself, and then only if you get a come-along to help close it LOL
decableguy2000
The link I posted earlier is for an XL case, The make a large as well and can be found with bits at Lowes with Flextorq bits or in Craftsman red. I have both the XL and large cases, got them from Ali express along with the holders. I cant tell if they are real or fakes. They do work well. I'll try to get pictures if you would like. The large has assorted driver bits and a set of quick attach drill bits, extensions etc. then I have 2 of the medium case on top with some mason bits and cabinet bits, and nut setters. I have a dozen or so small cases, that are empty right now. It is nice being able to have things in one place.
Sanderguy777
midwest
I ended up getting the large Toughcase, and pairing it with a medium. It doesn't mount to my packout, but I have enough aftermarket parts that I can probably get it to work. Might even add a Tstak case to replace the half-size packout I use.
