dagofast
It takes some patience. The top bracket is slotted for left/right and front to back movement. Once I figured out the best place for the front to back to back position, I began to focus on side to side. I found the approximately 1/2" slot in the frame where the blade passes was square to the work piece backstop so using the sideways slots in the top bracket, I squared the front of the blade up in it. Then use the two big knobs square up the rear of the saw blade. You can also get some trigger adjustment using those 2 big knobs to adjust the height at the rear of the saw up or down. Like I said in my review, it takes some fiddle farting around, but since my saw will likely live in this stand, I didn't begrudge the process taking longer than it should. If they had built the stand to only accept one specific saw, I'm sure a direct drop in and bolt up solution would be a piece of cake, but having to fit 4 different brands made it what it is.I bought the new chopsaw frame for the portaband. I am not impressed. It's been a real pain to setup so far. I made one cut that was pretty crooked, after spending a lot of time checking for square and clamping the saw in place.
There's no great way to clamp a workpiece without a specific clamp that isn't included. C-clamps doesn't work, and the frame floor doesnt allow for typical locking visegrip type clamps. The on/off trigger setup is pretty useless, but maybe more finnageling and I'll get it figured out. The stand is adjustable but fitment still manages to ****. The blade should easily align with the opening in the frame floor, however it is physically impossible to attain that when using the Bauer saw. I like the Bauer saw, but in the frame it just isn't working well. I'll update if the weekend brings about better results.
HF sells this drill press clamp: https://www.harborfreight.com/9-inch-drill-press-locking-clamp-36221.html I pulled it off of my little drill press table and it works okay to hold the work piece in the saw stand but a slightly bigger size would work better.
